Is this a good stall for a DD?
Old 07-18-2013, 11:23 PM
"I MAID THEESE"
Mavn's Avatar
Default Is this a good stall for a DD?
Hello! I have a bolton ls1 and am about to get a small cam. Found this guy that sells lsx parts in houston. Would this be a good DD stall for a smaller cam? Thanks!
http://houston.craigslist.org/ptd/3862620145.html
Old 07-19-2013, 12:02 AM
skeeterboy's Avatar
Based on my research most guys on here are going to say with an ls1 no less than 3600 stall and most are split on the 4000 stall.
I personally just bought the 3000 to 3200 converter that is in the craigslist ad from Circle D which sells to Chuck. I got to meet Chris and he answered all my questions. Real personable guy.
I chose to do the lower stall because I never have had one beyond stock, my transmission is currently being rebuilt by Gilbert at Ace, and I am building this car to be a daily driven street car with an occasional get on the gas if I want to.
I don't have an aftermarket cooler and the higher stall will produce more heat than stock.
Once I get to drive it I will let you know what I think. There are a lot of daily driven ls1 motors with higher stalls.
Old 07-19-2013, 01:53 AM
Kingc8r's Avatar
Not bad and will be an improvement over stock. I daily drove a SS3600 and after a week I was used to it, now I have a 4000 lol
Old 07-19-2013, 09:55 AM
vwdave's Avatar
Chris from Circle D is a great guy. I will be purchasing a Converter and flexplate from him whenever the funds become available.
Old 07-19-2013, 11:10 AM
thunderstruck507's Avatar
Unless you are planning a really small cam I would step up to a higher stall.
That would be a good one for a daily driver with bolt ons though.
Old 07-20-2013, 06:22 AM
jmmcamaro2002's Avatar
I just installed a 3200 stall in my Camaro. It is my daily drive and it will most likely stay with the stock cam, maybe a small one the distant future. The car will not see the track, but I wanted to have a little more fun and try a higher stall than stock. It is a little bit different than stock, but I am not impressed.
Old 07-20-2013, 07:59 AM
FirstYrLS1Z's Avatar
https://ls1tech.com/forums/automatic...convertor.html
Old 07-28-2013, 02:02 PM
RedFirehawk's Avatar
A high stall on a stock rearend with sticky tires will kill your rear end fast. I would stay with a lower stall on a stock rearend unless you plan on upgrading it soon.
Old 07-28-2013, 02:32 PM
TA_Freak's Avatar
I had a 3200 and hated it. I pulled it and went down to a 2500 and love it. I guess it comes down to preference. Also my rear is the stock 2.73, so that plays into it. Plenty of stall in case I want to install a mild cam in the future.
Old 07-29-2013, 09:47 AM
mjs1012's Avatar
Originally Posted by RedFirehawk
I high stall on a stock rearend with sticky tires will kill your rear end fast. I would stay with a lower stall on a stock rearend unless you plan on upgrading it soon.
This is not entirely true. There are many people running a high stall with drag radials that have not had an issue with their rears. Depends on how you drive it also.
Old 07-29-2013, 06:37 PM
Its Mostly true. I have seen post after post over the years of peeps blowing up their rear ends with high stalls and stickys.
Old 07-29-2013, 07:46 PM
Blackpanther99's Avatar
Agreed. With a good tune and a small stealth cam it will be a good DD stall.
Old 07-30-2013, 04:07 AM
TXZ28LS1's Avatar
I had a vigilante 3200 stall, then switched to a circle D 4000 stall. It drove just the same as 3200, but was a monster when you punched it.
You can daily drive a 4000 stall easily..
Quick Reply: Is this a good stall for a DD?
