What's the lowest boost you can launch a car of with no co2?
Old 07-19-2013, 05:49 PM
SPRAYED 01's Avatar
Default What's the lowest boost you can launch a car of with no co2?
Im looking into all different kind of serious boost controllers. What i need to be able to do id run as little as 2,3 psi on the trans brake and then have it ramp in all the way to 22ish.
I called turbosmart and they say you can use a 3lbs spring and launch on that. Then it would ramp in after launch. They claim this can be done with no co2 or compressed air.
I have measured back pressure on my setup. At 20psi intake I'm at 35 psi exhaust. I don't think that would work well with out compressed air. I have no issue running it just wanted too see what you guys think of their claims.
Im not dead set on that controller just exploring options.
Alex
Old 07-19-2013, 05:51 PM
SPRAYED 01's Avatar
Im refering to the eboost 2 from turbo smart. But the Thery applied to any boost controller
Old 07-19-2013, 07:00 PM
koolrayz's Avatar
I believe the spring I use is a 1.7 pound. Call Tial up and they can hook you up
Old 07-19-2013, 07:01 PM
SPRAYED 01's Avatar
But can that be controlled up to 20psi without co2?
Old 07-19-2013, 07:08 PM
SPRAYED 01's Avatar
What gate do you run?
Old 07-20-2013, 04:46 AM
stevieturbo's Avatar
For that sort of variation in boost I'd say it would be impossible without some sort of compressed air source.
Whether that is CO2 or simple compressed air via a compressor and reservoir.
Obviously CO2 would be easier, but eventually it will run done
Old 07-20-2013, 10:51 AM
skinnies's Avatar
You can only make around double the spring, so if you run a 10lb spring can run 20lbs. This is the huge advantage to running co2(or on board air). I run 1.5lb springs in my setup.
Old 07-20-2013, 01:43 PM
SPRAYED 01's Avatar
That's what I thought to. The lady at turbo smart did not seem to knowledge but insisted on taking on my tech question. She thinks you can run a 3lbs spring to 20lbs with no compressed air.
Quick Reply: What's the lowest boost you can launch a car of with no co2?
