Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
msd 6010
Old 07-23-2013, 02:25 PM
6secNaLs1's Avatar
Default msd 6010
i have a 06 ls2 motor with a 24 tooth wheel..will the ms6 6010 cam sensor plug be long enough to go to the front of my timing cover.
thanks
Old 07-23-2013, 02:28 PM
camaro98rs's Avatar
I dont think it will be you may have to get an extension harness for it.
Old 07-23-2013, 02:49 PM
onefast84's Avatar
No you will need the MSD 6012 which is for the gen iv motors. No extension harness it is for using fuel injection.
Old 07-23-2013, 03:07 PM
camaro98rs's Avatar
but he says his motor has the 24tooth reluctor wheel and not the 58. so the 6012 box will not work for him even though he has an ls2. so he would need the harness from the 6012 or an extension harness for the cam sensor.
Old 07-23-2013, 06:17 PM
6secNaLs1's Avatar
Correct it has the 24 tooth. Not the 58 . Who sells the extension harness
Old 07-23-2013, 06:53 PM
In-Zane Moderator
ZONES89RS's Avatar
Extend it yourself.
Old 07-23-2013, 07:02 PM
rojs234's Avatar
You are correct that your engine requires the MSD 6010. Several of the early Gen lV engines had 24X reluctors. I have a 24X LS2 and a friend has a Gen lV 5.3 aluminum block 24X. That said... you need to do 2 things to make it work. You have to extend the wires on the MSD cam sensor plug by about 3 ft. and you need to switch the 2 outside wires in the plug.r If you look at the plug, these are labeled A and C. The easiest way is to just switch them when you're extending them. After you do this, the plug will plug in to the sensor in the front cover. If you don't switch the wires, the engine will most likely just backfire through the carb. Ask me how I know...LOL.
Old 07-23-2013, 07:21 PM
6secNaLs1's Avatar
Yep found that info thanks
Old 07-24-2013, 06:47 AM
Pop N Wood's Avatar
By the way, the "extension harness" MSD sells isn't an extension, it is a compeltely separate harness used when mounting the box on the intake. it is actually shorter than the one that comes with the box.
Old 07-24-2013, 08:54 AM
onefast84's Avatar
Oops I mixed up the wheels.
Old 07-24-2013, 02:46 PM
4drnova's Avatar
I got my extension harness from casper
Old 07-24-2013, 05:38 PM
wildcamaro's Avatar
The MSD 6010 I got came with wiring harness set up to run box in the intake...
Old 07-26-2013, 08:13 AM
MikeFSKSpeed's Avatar
You have cut and extend the wires if they dont reach, no problems there.
Mike
Old 07-26-2013, 10:04 AM
onefast84's Avatar
Would a 6012 cable fit a 6010 box? Maybe call MSD and see if they will sell you one if it fits.
Quick Reply: msd 6010
