Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
mounted my map sensor
Old 07-26-2013, 08:16 AM
Silver Sleeper's Avatar
Default mounted my map sensor
clean and out of the way. GMPP single plane intake
Old 07-26-2013, 08:57 AM
MikeFSKSpeed's Avatar
Nice! and that black wrinkle finish looks GREAT
Old 07-26-2013, 09:58 AM
thank you!
and thanks for the msd 6010, i ordered it from you guys a while back...best price around
Old 07-26-2013, 04:37 PM
In-Zane Moderator
ZONES89RS's Avatar
You drilled a hole? I'm still not sure how I will mount one but that looks like a stock truck MAP right? Or somewhere along that line?
Old 07-26-2013, 07:29 PM
snook's Avatar
My brother gave me a piece of chrome sheet metal, think it was a valve cover wire separator piece. Drilled a hole on both ends, stuck a piece of tubing on it. Its under the carb bolt
Wrinkle black intakes FTW!!!
Old 07-27-2013, 08:12 AM
yeah i drilled a hole a little smaller the the orange grommet. fits nice a tight. its a stock truck map sensor
Old 07-27-2013, 09:06 AM
Pop N Wood's Avatar
Sweet. I like that
Old 07-27-2013, 07:06 PM
In-Zane Moderator
ZONES89RS's Avatar
Pic of the hole when drilled?
Old 07-27-2013, 07:30 PM
yeah, hang on a minute...
Old 07-27-2013, 08:22 PM
here are more pictures... i started the hole with a small pilot hole.. used calipers and measured the outside diameter of the orange grommet..a 3/8 drill bit was the ticket. the map sensor fits nice and snug without ripping the orange grommet.
Old 07-27-2013, 08:23 PM
nice setup!
i agree...wrinkle black is awesome..its a trademark feature of most of my builds
Originally Posted by snook
I used a piece of chrome sheet metal, think it was a valve cover wire separator piece. Drilled a hole on both ends, stuck a piece of tubing on it. Its under the carb bolt
Old 07-27-2013, 08:31 PM
In-Zane Moderator
ZONES89RS's Avatar
Nice, that's some good visual for anyone looking to do the same.
Old 07-27-2013, 08:32 PM
Treyvs's Avatar
I'm looking for a MAP sensor right now. I found one for the Gen III's (I am running a 2007 LM7). How do I know if it is the correct one? The part number I am coming up with is 12614970. Looks a tad different than the one in your photos.
Old 07-27-2013, 08:51 PM
glad to help.. i know that the map sensors are a hot topic in the carb section
use the part number listed on my map sensor above.. my motor came from a 2002 1500 sierra and i saw and heard it run before the motor was pulled so i know it works
Trevor
Old 07-27-2013, 08:54 PM
http://www.ebay.com/itm/16249939-161...-/110858583219
Old 07-27-2013, 08:59 PM
Treyvs's Avatar
Thanks, and as said above, this is almost en essential post to view when doing a carb application. Well done, sir.
Old 07-28-2013, 08:49 AM
you are welcome, glad to help out
Old 07-28-2013, 10:48 PM
In-Zane Moderator
ZONES89RS's Avatar
I have so many truck intakes laying around it is pathetic. 99-02. The map sensors are always broken or I use them on swaps.
Old 07-28-2013, 11:19 PM
it looked like mine had been recently replaced before the truck got my motor out of was rear ended..
Old 07-29-2013, 09:11 AM
Pop N Wood's Avatar
I'm usind a map sensor off a v6. Pretty much if the plug matches it is a go. Pick and pulls give them away
Quick Reply: mounted my map sensor
