cam choice
cam choice
Really need help with a cam choice. I got a shortblock today I have a cam for sale / trade if u look at the posts. I needing a hyd cam. Pretty big in size. Looking 600+ wrhp na.. and il be spraying nitrous. 300 max. Need help from martin smallwood... brian tooley.. or richard. These guys are highly respected. Needing to order a cam soon so can get in by next weekend. Running set all pro heads lsw1s. 700 lift springs.. if anyone needing me email the paper of heads. Lmk. Also wating run 12.-12.7 compression.
Do you have Money.....If so call Mars at TICK performance = Cam....or Mr. Tooley = Springs and the whole aspect of things. There # is on this Forum and Richy Richy @ WCCH = Comp.ratio wanted. Money is Required pick up a Phone!
Brandon,
I have some lobe profiles at the shop that will work well with those heads, I don't have the lobe information in front of me right now though.
I have the cam specs we talked about from a month or two ago from the first set-up you had planned and I have a new set of specs for this set-up as well we can go over.
I think you'll like the profile I spec'd out if Brian hasn't already ground one for you yet.
Still need help deciding on the fast 102.. holley hi ram.. and also a good lifter.. the new short travel lifters with tie bars or the lunati race version(morels replica)...
Yes. Ima go ahead and get the lunatis version of the morels. Maybe get them from brian tooley. Also going ahead decide on the fast 102. And get it ported as well. Guess all I need now is get the right pushrod length amd good set rockers. Since I have bronze guides. Been told by respected guy have use a roller rocker. Roller rockers be less expensive then getting the heads redone
I responded to your E-mail regarding the rockers Brandon. I would recommend the roller rockers as well so that we can run more valve lift and utilize the heads that you have.
I also agree on the Fast 102, there are guys making 600rwhp with Fast 102's in 427-440 C.I. set-ups with heads like yours.
Can't wait to get this thing going Brandon! It's gonna be nasty!!! I can also get the lifters for you as well.
