00 Z28 problem
00 Z28 problem
I have a 00 Z28 and I just installed a 3000 TCI stall, Pacesetter L/Ts, y pipe, removed the EGR and AC. Started the car and it sounded great for about 5 minutes and then it quit. I started it back and it sounded like it was only running on 6 or 7 cylinders and now it wont start at all. Any suggestions on what could be wrong?
Well I found out if I take a spray bottle and spray gas in the throttle body it will start so it's fuel related. Checked the fuel pressure and its right and checked all the injectors and they all pulse when cranking it.
still having the same problem. I pulled the tranny back out thinking maybe I pinched a wire but that wasn't it. When I pulled the y pipe off gas ran out of the passenger side header so its deffinatly getting gas but it will still start when I spray gas in the throttle body.
Check the temp sensor on the driver side, I think. I had mine unplugged and the car wouldn't run for more than a few seconds. It definitely gets gas, mine flooded with the sensor unplugged.
