I am using a Holley Dominator EFI and a FAST 4150 4 bbl throttle body. Since there is no intake elbow, I made a little bracket that mounts to the carb stud for the IAT sensor. Will this work? If not, please point me in the right direction. Thank you
Do you have room to just drill a hole slightly inboard of the air filter in the bottom of the air cleaner. It should read close where you have it but in the air cleaner is the best spot.
It will be fine.
If this is a race car (no air filter) I can tell you that most drag racers don't even use one. They just leave it off & leave that table blank.
