IAT Sensor
Old 08-01-2013, 10:16 PM
4drSupraT78's Avatar
Default IAT Sensor
I am using a Holley Dominator EFI and a FAST 4150 4 bbl throttle body. Since there is no intake elbow, I made a little bracket that mounts to the carb stud for the IAT sensor. Will this work? If not, please point me in the right direction. Thank you
Old 08-01-2013, 11:27 PM
greenvortec97's Avatar
It should work if you recalibrate the IAT sensor
Old 08-02-2013, 12:25 AM
01WS6/tamu's Avatar
Do you have room to just drill a hole slightly inboard of the air filter in the bottom of the air cleaner. It should read close where you have it but in the air cleaner is the best spot.
Old 08-02-2013, 06:36 AM
Not running an air filter. What do you mean by recalibrate
Old 08-02-2013, 08:07 AM
Gray86hatch's Avatar
Looks like it will be fine. I have mine in the pan. Your # will higher with no pan
Tim
Old 08-02-2013, 08:13 AM
9-Second Club
Ed Wright's Avatar
It will be fine.
If this is a race car (no air filter) I can tell you that most drag racers don't even use one. They just leave it off & leave that table blank.
Quick Reply: IAT Sensor
