A/C problem
A/C problem
So getting my other problems dealt with im fighting another with the A/C that has been acting a pain for the past several days. AC is blowing out hot air some days & colder air other days. On those “Colder days” it still doesnt blow as cold as it use to prior to the issue. Checked the compressor and it turns on fine. Was trying to find a leak and sometimes(not always) hear a leak near the Evap. One guy looked at it and told me that there was air in the system - that I needed to replace either the Accumulator or Evap Drier. He may be right, but if either of which are going bad wouldnt it be blowing hot air all the time? Had the Freon checked and there is the adequate amount. I had a few ideas of my own about the issue:
-A/C heater blend door getting stuck (tried turning on & off heater a number of times)
-A fuse
-Obviously a leak
-Computer problem
-System Recharged
-Orifice tube
Any ideas that I might have or havent covered, maybe I already answered my own question?!
-A fuse
-Obviously a leak
-Computer problem
-System Recharged
-Orifice tube
It won't be the orifice tube. The system uses an expansion valve, instead. Often a professional evacuation and recharge can give it some more life. That got an extra two years out of mine before the compressor finally gave up.
I should add that a several weeks ago, one morning on my way to work and found the whole carpet near the dash, my feet, near the peddles, passengers side was soaked with water. Water coming out of underneath the glove box, out of the feet vents, and near the floor side of the radio. At the time had no idea, but did some research on here and found out that it might of had something to do with the A/C. Sounds like a Leak but what exactly would leak to have water soaking from under the whole dash front of the car?
Has the system been open at any time recently?
Like was said above, the heater core is probably what left the water in the floorboard, although I've had the same thing happen when water filled the system in my 3.8 grand prix because the drain on the ac.
https://ls1tech.com/forums/general-m...-question.html
Village Troll
This morning the a/c was blowing somewhat colder, but then heated back up by the time I got back home..
