Non intercooled + loads of meth?
Anyone making big power with a non intercooled setup and loads of meth?
Contemplating losing my intercooler as it just might be a restriction for my motor and 1/8 racing and run 3 or 4 meth nozzles with pumo gas.
Also lose a few pounds off the front end.
My intercooler is only 3" outlets and ebay version.
Anyone making big power without an intercooler on 100% meth?
https://ls1tech.com/forums/forced-in...rformance.html
I think these guys are running non-intercooled exactly like you are looking for.
Thats what I was thinking. Im thinking of doing non intercooled and 2 big nozzles under 15psi then throw c16 in the tank and turn off the meth.
I've blown a couple motors going this route. Granted it was a stock shortblock, and I'm not a ***** when it comes to throwing boost to a motor. If I were to try it again, I would have a progressive on the meth, I would use ethanol in the tank instead of methanol as to make tuning more consistent and less complicated. I would ditch the LS6 intake because I'm not totally sure it was distributing the amount of meth evenly.
Maybe look into a dual nozzle setup and use a meth/water mix. Have one nozzle right after the compressor housing of the turbo and another right before the TB - depending how long of a run that pipe is. You'd probably be alright if the first came on at 1psi and the other at like half your total boost maybe? Just speculating/brainstorming
I sprayed pre compressor and it helped a lot. This pass was with one nozzle pre compressor and one after. One nozzle only kept the IATs to like 240*. The one pre compressor lowered it to 185* by the 1/4 traps
Pre-compressor is a huge help. It also will increase compressor efficiency by decreasing outlet temps from running high boost levels. Cameron did you see a boost increase when you went pre compressor with the same gate settings? I've heard some people say that they gained boost psi when spraying pre compressor.
I believe one of Lil John's customers that runs Ultimate Street runs C16 blow through carb with M1 methanol injection and has been as fast as 5.28@135 IIRC.
Good tuning and diligent plug reading will allow a non I/C set-up to run it's best IMO. I have thought about running C16 in mine as well.
Thats good info!
You see what I was thinking is run my original dual meth nozzles before the tb then run one pre compressor.
I am currently running a -10 and -14 before my tb.. would you recommend going larger? Also how big of a nozzle should I run pre compressor?
I could do that for the street and throw c16 in the tank when I get to 18-24psi if need be!
