confusing RPO codes
confusing RPO codes
I keep reading 1SC is stripper 1SZ and all kind of numbers but mine has me way confused, then I read 1SC is SLP or something I have no idea
then you read the 1SZ is a package with limited slip and other stuff, F41 handling, I know I don't have an open carrier, because it will lay a pair until you take your foot out of it
can someone give me an idea of what the hell I have..
man I am confused..
Edit.. I got it at a Florida State auction..
man I am confused..
Ua6 theft deterrent system anti-theft(ua6) 28,871
ub3 cluster,instrument(oil,coolant temperature,voltmeter,tachometer,trip odometer) ga(ub3) 37,998
um6 radio,am/fm stereo,cassette,etr,includes clock stereo cassette(um6) 5,148
uq0 speaker system,4,dual front door mounted,dual standard range package shelf/quarter 4 spkr sys(uq0) 5,148
u73 antenna,fixed fixed ant(u73) 35,884
vm3 label information consumer, contains bpr imp standard for frt 5 mph & rr 5 mph 5 mph bumper info label(vm3) 30,255
v73 vehicle statement - us/canada us/canada vehicle statement(v73) 35,682
1ay order modification - stock 20,768
1sc package-option 03 (1sc) 14,406
1sz package option- (1sz) 35,143
28u exterior color,primary,black sapphire metallic (28u) 4,597
52b trim combination cloth, lt neutral (52b) 3,267
52i interior trim light neutral (52i) 5,946
6pw component frt lh comptr sel susp(6pw) susp(6pw) 18,271
7pw component frt rh comptr sel susp(7pw) susp(7pw) 18,271
8tj component rr lh computer sel susp (8tj) susp(8tj) 32,086
9tj component rr rh computer sel susp (9tj) susp(9tj) 32,086
ah3 adjuster,seat,4-way manual,driver 4-way man d/seat adjr(ah3) 12,992
ak5 restraint system,front seat,inflatable,driver and passenger driver & pass f/seat infl rst sys(ak5) 37,997
ar9 seat,front bucket,driver,passenger,manual reclining(european style) man recl frt bkt st,deluxe(ar9) 36,720
au0 lock control,remote entry(keyless entry system) remote entry lk cont(au0) 28,870
au3 lock,side door,electric elec s/d lk(au3) 34,700
a31 window,power operated,all doors pwr windows(a31) 30,226
a90 lock,rear compartment lid,remote control,electric release elec rel lid lk(a90) 33,776
cc1 roof,hatch,removable panels,glass hatch rf(cc1) 23,929
c49 defogger,rear window,electric elec rr wdo defg(c49) 31,126
c60 air conditioner,front,manual controls a/c man cont(c60) 37,997
de4 sunshade,removable hatch roof hatch rf s/s(de4) 23,929
dg7 mirror,outside,rh & lh remote control,electric(painted) o/s elec r/con painted mir(dg7) 28,052
dl5 decal roadside service information roadside service info decal(dl5) 35,143
fe9 federal emission certification fed emis(fe9) 26,834
f41 suspension,firm ride handling,front and rear firm ride & handling susp(f41) 23,054
gu4 axle,rear,3.08 ratio 3.08r(gu4) 14,188
ipb trim,interior design (ipb) 24,627
j65 brake system,power,front and rear disc 4-whl disc brk(j65) 37,997
k34 cruise control,automatic,electronic crcont(k34) 34,676
k68 generator,105 ampere 105 amp(k68) 23,054
l36 engine gas, 6 cyl, 3.8k, mfi, v6, ho (erv6 series) 3.8k(l36) 23,054
mx0 transmission,automatic,overdrive(merchandising option) a/trans provisions(mx0) 26,486
m30 transmission,automatic 4 speed,4l60e,electronic 4-spd a/trans(m30) 26,486
nf2 emission system,federal,tier 1 fed emis sys(nf2) 26,975
np5 steering wheel,leather wrapped leather wrapped strg whl(np5) 29,684
n96 wheel,16x8(cast aluminum) al whl(n96) 20,206
qcb tire all p235/55r16 bw r/pe st tl al2 96t tire(qcb) 20,366
r7a control - sales item no. 26 15,241
ste plant code- st therese, pq, gm of canada st therese,gm of canada plant code(ste) 37,998
t82 headlamps,automatic on/off control auto hdlp cont(t82) 35,884
t96 lamp,front fog(used with touring yp6) frt fog lp(t96) 33,228
reason I ask is everywhere you read even on these forums I don't even know what the heck that is, I'm new to camaro's
if your rpo codes have 1sc and 1sz, your car is a stripper camaro
I'm late to the discussion here, but here's what my research has found about stripper Camaros:
'Stripper' is the term people refer to when talking about the no option base model Z28 or SS. In 1999, the base model was the 1SD option code and in 2000-2002 the base model was the 1SC option code. The base model comes with no power options (seats, mirrors, windows, locks, cruise, remote hatch release, fog lights, remote entry, body moldings, etc).... Basically stripped, hence the 'stripper' term.
In 1999, there were only 459 1SD cars made, so that makes them sort of rare, but not GNX rare where the value has tripled since new.
There is also a debate, it seems, where some claim the stripper car is lighter, therefore better for racing. Other people don't agree with that claim and would rather have power windows. I can see it both ways.
1998 v8 Camaros- 1SF base model coupe
1SG power optioned coupe
1999 v8 Camaros- 1SD base model coupe
1SE preferred equipment group 1 (most power options)
2000-2002 v8 Camaros- 1SC base model coupe
1SD most power options
Hope that helps.
Hope that helps.
more questions
I have a 2002 Z28 that has the 1SZ code, along with 1SP, and it has the electric controls, doors, windows, rear hatch, etc...
Anyone know what the 1SP is?
