wireing an LS alternator in a 1962 impala
Old 08-18-2013, 04:44 PM
Lee Thompson's Avatar
Default wireing an LS alternator in a 1962 impala
I know which of the 4 holes to put the 1 wire in (3rd hole from center of engine) What I need to know is this ( I have been told and read where I need a resistior in this wire.) I did this and now still have 12 volts @ the end of wire. I would think that I should be seeing 5-6 volts with key on. Haven't checked with engine running. This is an alternator for a 2000 truck. Thanks---Lee
Old 08-18-2013, 06:59 PM
S10xGN's Avatar
With the key off, you should have 0v at the "L" terminal (if that's where you are) of the alternator. If you're checking the harness and not the alternator, you should have battery voltage with the key on and 0v in off. After cranking, that alternator pin will start producing to 12v which cancels out current flow and turns off the lamp.
Old 08-19-2013, 08:57 AM
Thanks for your reply--just to be clear--I have run a seperate 12v wire from the fuse box to pin L on the alt. plug with the recommended resistor. With key on I am seeing 12v @ pin L----I would think the resistor was supposed to drop it to 5-6v. Am I wrong or just a non-electrical brain. Thanks---Lee
Old 08-19-2013, 12:40 PM
Gray86hatch's Avatar
Best way to fix this I have found is to have a self exciting regulator installed. True 1 wire hook up don't have to mess with the resistor.
Tim
Old 08-19-2013, 06:20 PM
S10xGN's Avatar
I'm pretty sure you'll see 12v until current actually flows. Checking with a VOM is not gonna cause any current flow as their internals are > 2 megaohms. Think of it like a water hose with a restrictor in it. When there's no flow through the hose, the pressure is the same on both sides of the restrictor, but when you start the water flowing the downstream pressure will be less...
Old 08-20-2013, 05:13 AM
fox12303's Avatar
That's how I see it too. Resistance is a function of voltage and current(flow). Most wiring diagrams show a two wire hook up but you are only talking about the one wire with the resistor.
Diagram: https://ls1tech.com/forums/13759335-post34.html
Old 08-20-2013, 10:56 PM
Chadsin's Avatar
On a side note. What exhaust are you going to run? I'm doing a 62 also and was just curious. Thanks!
Old 08-21-2013, 10:19 PM
Stormed_Norm's Avatar
ls1 s-10 headers work pretty nice. That's what I used and have no complaints.
Old 08-23-2013, 07:48 AM
Default I see
Thank you--Lee
Old 08-23-2013, 07:53 AM
Default exhaust
I bought new LS3 exhaust manifolds off E-Bay ($30). Reason I went with those is because it appeared they would work with my 4 speed clutch linkage. Have the engine in the engine bay and had to notch the frame slightly---next week I am going to fab. 2.5 in. mandrel bend ells to my current exhaust..---Lee
Quick Reply: wireing an LS alternator in a 1962 impala
