fox mustang with ls2 oil pan? HELP!
Old 08-20-2013, 11:45 PM
93Fox's Avatar
Default fox mustang with ls2 oil pan? HELP!
I have a line on an ls2 "batwing" oil pan. Looking at dimensions it looks like it will be close to fitting into a fox chassis car. Anybody done this? I am running an aje k member.
Old 08-21-2013, 07:06 AM
brewster240's Avatar
ls2 comes in several different cars, there is no "ls2 oil pan"
the batwing pan is out of a corvette, the years before ls2.
Old 08-21-2013, 09:03 AM
usdmholden's Avatar
Having put an fbody oil pan into a Mustang with an aftermarket 4.6 k member, I don't see how you would make a Corvette oil pan fit and still be able to run the exhaust between the frame rails and firewall.
I'd pass on the Corvette pan, but you could try it if you wanted. You will have to try it to know for sure.
Old 08-21-2013, 12:23 PM
93Fox's Avatar
I will be turbo eventually. And Brewster I specified "batwing" out of c5 I believe? Could be wrong on year. So it has never been done?
Old 08-21-2013, 04:00 PM
you said ls2 batwing, not corvette batwing.
ls2 didnt come with batwing. the vettes with ls2 had a different pan.
any pics of what you have?
Old 08-21-2013, 05:06 PM
93Fox's Avatar
I don't have anything, wondering on buying one. I believe it came from a c5 judging by what I can see from his page. There is only one bat wing correct?
Old 08-21-2013, 07:56 PM
BigEd_72455's Avatar
If below is the oil pan you are referring to, WHY would you want that hideous thing...
I really doubt that it will fit the fox cross member regardless of what stock or aftermarket one you use...
Attached Thumbnails fox mustang with ls2 oil pan? HELP!-29894412-485-ls1-batwing-oil-pan.jpg
Old 08-22-2013, 08:12 AM
usdmholden's Avatar
Turbo or no turbo, exhaust is still exhaust.
I don't see how the batwings would fit relative to the frame rails and control arms unless you cut it up and re-weld it. Then still, the batwings consume all the space where the exhaust would go.
Old 08-22-2013, 09:37 AM
93Fox's Avatar
Planning on fender exit I think I will pass on it. Just wondering if it had ever been done
Quick Reply: fox mustang with ls2 oil pan? HELP!
