Belt pn modular turbo alternator relocation
Old 08-21-2013, 07:43 AM
Cam72aro's Avatar
Default Belt pn modular turbo alternator relocation
Does anyone know the belt part number for the modular turbo alternator relocation kit? I shredded the belt and need a replacement. I have a few extra minutes to kill as I wait on the side of the road.
Old 08-21-2013, 12:39 PM
Cam72aro's Avatar
Or the length?
Old 08-21-2013, 05:03 PM
Cam72aro's Avatar
406072 is the part number. 72" 6 rib is what it is. Thanks for all the help.
Old 08-22-2013, 06:55 AM
LT1TA's Avatar
thanks for the info. someone will find this useful later. (myself lol)
Old 08-22-2013, 06:58 AM
Cam72aro's Avatar
I figured it would be useful to someone out there. I did a lot of searching and had to find it on my own. At least I can help someone else out.
Old 08-22-2013, 07:00 AM
LT1TA's Avatar
People like you are why I continue to visit this site. I appreciate being able to resource threads without ego flexing and battles between the know-it -all's who are usually half wrong.
Old 08-22-2013, 09:07 AM
Cam72aro's Avatar
I appreciate it bro. Everything I do is real world budget go fast, and I try my best to help others out. A good bit of advice to anyone still using the stock plastic ps pulley is to replace it with a aluminum one. Mine lost the bond between the plastic and the steel sleeve causing the pulley to wobble and touch the ps reservoir. It sliced a hole in it putting fluid everywhere and turned the belt to mush. I noticed temp coming up and volts going down. I shut it down and coasted to the side. New belt, aluminum pulley and reservoir are on the way.
Old 08-22-2013, 09:59 AM
edwardzracing's Avatar
Can I get a little more information? What is your accessory setup? Is that the correct length for alternator, power steering, and stock sized crank pulley without any tensioner? Please let me know. Thanks!
Old 08-22-2013, 10:11 AM
Cam72aro's Avatar
Modular turbo alt relocation, ps pump, stock sized crank, stock wp pulley. No idlers, etc. the tensioner is the alternator. Modular turbos website says 72" length, so I researched and cross referenced to a Goodyear gator back 72" length and 6 ribs.
Old 08-22-2013, 11:00 AM
Perfect; exactly what I was after. Thank you! I appreciate it.
Old 08-22-2013, 11:37 AM
Cam72aro's Avatar
No worries man. Glad I could help. Good luck with the car. If you need anything don't hesitate to pm me.
Old 08-30-2013, 11:06 PM
Cam72aro's Avatar
Just an update. Got my new pulley on with this belt. Everything is great. Belt fits, is correct length. 406072 Goodyear gatorback belt.
Old 08-31-2013, 02:35 AM
Confirming excellent fitment with a 72" belt. Thank you again!
Old 08-31-2013, 09:32 AM
Cam72aro's Avatar
Glad I could help.
Quick Reply: Belt pn modular turbo alternator relocation
