piston blew up? motor options/thoughts
Old 08-25-2013, 10:47 AM
burbalanche's Avatar
Default piston blew up? motor options/thoughts
what would cause this?it was cylinder 8 that went.was at a cruise yesterday around town and was getting on the highway and all the sudden herd somthing break and that was it.got it home and dropped the pan and thats what i found.running e85 12-14 boost on a 03-04 6.0.just switched from a 6 speed to a th400 also and first time out.never did any hard pulls or anything just slow cruising and some into it a little.could it be caused by it being way to lean from switching trans?my tuner said there was no need for retune?
Old 08-25-2013, 11:19 AM
Preston99WS6's Avatar
When I swapped my tune was all screwed up as soon as I started the car it was evident, the part throttle tables had to be adjusted with the EFI live 3 bar OS not sure what you were using to tune but that was my experience. My car was pretty lean, did you have a wide band on the car by chance?
Old 08-25-2013, 11:49 AM
SPRAYED 01's Avatar
Even if the tune was off a little you said you were not in the throttle, right?
Old 08-25-2013, 01:20 PM
stevieturbo's Avatar
pictures.
Old 08-25-2013, 05:35 PM
Blackpanther99's Avatar
X2^^ Post pics.
Old 08-25-2013, 06:27 PM
No i was not hammering on it at all.i do have a wideband and i cant figure out how to post pics.piston is in 2 chunks and **** to of little pieces.rod was still torqued to crank tight and wrist pin still in tacked.it bent the rod slight but i assume it was after the puston went.
Old 08-26-2013, 06:31 AM
Old Geezer's Avatar
No pics, no data = difficult to make an assessment.
Old 08-26-2013, 09:43 AM
Forcefed86's Avatar
You detonated for some reason or another. Doesn't take much on the OEM parts. Would need to know your timing/AFR compression etc to make a guess. Could be bad gas as well. I've seen some pretty low ethanol percentages at our pumps in KS.
Old 08-26-2013, 10:12 AM
Well i guess im sol.i cant upload pics.only ones i got rigjt now is a pic of a split piston bent rod and lots of little pieces.compression is stock lq4.afr was around 17 cruising.timing idk tuner never told me.tune was conservative but i switched from t56 to 400.fuel i tested and was right about 85%
Old 08-26-2013, 10:37 AM
68 SS's Avatar
The load on the engine between the two transmissions is very different, most likely this is what ended your piston's life. Even at part throttle and light loads it can detonate and rattle the piston and with stock pistons it won't take long. Any change in the car the tune needs to be looked at always better to be safe than sorry. The bent rod is likely a result of the piston cocking in the cylinder after breaking.
Old 08-26-2013, 11:56 AM
Well i will get a further look when i get it out and torn down...on the other side of it what do u guys think about throwing a 4.8 in the mean time?would it be worth it?its a 2006 with 115k on it for 450 bucks.or should i look into somthing else?i can pick up another 2005 6.0 right now with 72k on it for 1400 though
Old 08-26-2013, 01:11 PM
Forcefed86's Avatar
Personally i've never seen a piston eat itself when not under a load. Unless the motor was built seriously wrong that just shouldn't happen. I'd guess whenever the last time you were on it hard it damaged the piston/rod and I just happened to let loose when you were cruising.
How much power do you want to make? 4.8's (esp 2005+) have been proven to make 700+whp semi easily. And they are more rev happy. I'd give the 4.8 a shot if thats enough power to make you happy.
Old 08-26-2013, 03:44 PM
LosLs1's's Avatar
I'm curious about this.. so the tune can change from 6speed to auto? I understand the loads will very but in wat way can it do that? I'm planning on doing the same move. Thanks
Old 08-27-2013, 06:56 PM
im in an about 5000lb lifted truck also.thats the only thing i keep coming back to but oh well to late now lol.
Quick Reply: piston blew up? motor options/thoughts
