Few Plug ID Questions On 99 Harness
I'm Working on a wiring harness right now , and there is a few plugs I'm Either not finding the Schematic on ALL data , or Mitchell. I'm beating my head against the wall trying to figure these plugs out. Harness is 99 Camaro Manual Trans.
I'm Going to Post the pictures of the connector , and where about it is located.
First plug is located about a foot past the connectors going into the column.
It's in the Harness coming into the car from the under hood electrical connector.
The second plug looks to go somewhere around the passenger side as its just a touch longer than the two interior connectors the ling to the harness.
The motor harness, The Interior Harness , and the Underhood fuseblock harness . The underhood is what the tac looking connector is. Let me take another picture here so you can understand .
As you can see the "pass thru" Then the rest is inside the car. There isn't another plug under the hood for a tac module.
I was told By the customer it was a 99 Camaro. I got it out of the car and fuse block was bolted in when I picked up the harness. While I enjoy wiring its always fun pickup up somebody's basket case. But I guess that why they pay for it.
Ok the bigger connector with the grey casing is for the air bag module that sits in the middle of the center console, the module looks like this:
The second connector plugs into the connector in the last picture that is very long,this one:
There should be two connections like that.
