2002 Trans Am 408 built! check out build..SOLD!!!
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $14000
Mileage: 78000
Private or Dealer Listing: Private Listing
Location (State): CA
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LINK ATTACHED TO FACEBOOK PHOTOS https://www.facebook.com/media/set/?...1&l=681f57403f
WALK AROUND VIDEO
MOTOR
408 STORKER 6.0L LQ9 Cast-Iron Short Block By TSP
Wiseco Forged Pistons -10cc dish
TrickFlow LSx CNC Ported Cylinder Heads 215cc Milled to 61
TSP Texas Giant Camshaft 248/245, .615"/.622" 112 LSA
Yella Terra Non-Adjustable Rocker Set
Powerbond 25% UD Balancer Pulley
Cometic MLS Head Gaskets .40 Thickness
MSD Blaster Coil
MSD Plug Wires and NGK Spark Plug
TSP Ported LS6 Oil Pump
In Motion Double-Roller Timing Set
Comp Cams 7.375 Pushrods
Comp Cams Hydraulic Roller Lifters
ARP Bottom End/ Head Bolts
92 Ported LSX Intake
95 PTM Throttle Body
100mm TSP MAF
102mm FAST TOY Lid
DRIVETRAIN
Moser 9 Inch With Wavetrac Differential, 35 Spline and 4.11 Gears
3.5 Inch PST Drive Shaft
Monster Clutch- Level 3
18lbs Flywheel With ARP Bolts
Tick Performance Adjustable Clutch Master Cylinder Kit
SLP Line Lock
Burkhart Chassis Manual Brake Cylinder
Burkhart Chassis Manual Steering Rack
Pro-star Rims With Mickey Thompson's
SUSPENTION
UMI Panhard Relocation Bar
UMI Panhard Bar Double Adj. (Chrome Moly)
UMI Lower Control Arms Double Adj. (Chrome Moly)
UMI Rear Drag Sway Bar (Chrome Moly)
UMI Torque Arm Adj. Brace Mounted With Drive Shaft Loop
UMI 3 Point Subframe Connectors (Chrome Moly)
Lower Control Arm Relocation Brackets
FUEL SYSTEM
F.A.S.T. 36 lb. Fuel Injectors
Warbro 255lph Fuel Pump
EXHAUST SYSTEM
Pacesetter Coated Headers
Off Road Y-Pipe
MaganaFlow Exhaust System
3" QTP Electric Cutout
EXTRA
Tick Performance Battery Relocation
ZEX Blackout Nitrous Kit
MSD Shift Light
CUSTOM
Nitrous Bottle Diamond Plate
Computer and Fuse Box Relocation
AC delete Panel and AC System Delete
Wire Harness Relocation/Tuck
Front End Brake line Set up (drop the K-Member without worrying about the brake lines)
Thanks a lot man. I miss El Paso... Never thought I would say that. Yea hate to see it go but just picked up a 2011 that I have some good plans with. I have a sale pending and will update if it doesn't sale. Thanks!
