BBK Intake with LS6 valley----Intake Leak
I recently did the LS6 valley cover swap on my car and now I have an intake leak on cyl #7. I have the BBK intake with 1 low-profile bolt in the passenger side rear. And I did cut the piece out of the block. I've already pulled the intake back off once to check if the gasket may have slipped somehow but all looked good . So I just threw the intake back on and it was still leaking at the exact same spot. The booster hose is on and so is the small hose on opposite side. NOTE *The LS6 valley cover does come with bigger (13mm instead of 10mm bolts) But I still used the low-pro on passenger rear.* I'm thinking I need to go pick up a set of those low-pro bolts and use them in all holes because maybe the intake is hitting the drivers side rear 13mm valley bolt?
So if anyone else has the BBK intake with LS6 valley cover, please chime in!!!
Update: Installed the low pro bolts on all valley holes and still is leaking on cylinder 7 at the top of where the head and intake meet. You can hear it sucking air and when you put your finger over it, the pitch changes. So once again, I pulled the intake and i'm trying to look over everything but no luck.
I'm using the LS6 coolant tubes. Brand new felpro gaskets and they look perfect. Have pulled the intake probably 6 times now. Cant find anything hitting it. Intake sucks down onto the heads but still somehow leaks at #7. Have swapped gaskets from runners to 7 and still a leak.
Yeah I tightened to what GM recommends. But this last time I ran down #7 some first then went and did the rest and it seemed to help. Drove it around and idles at about 14-15 AFR which is what it was before. WOT is still 12.5 lol. You can still put your finger on that runner and hear a tiny bit of sucking but not as bad. So I think i'm just going to leave it alone.
It's important you follow the torque sequence, and you will need to repeat it as many times as necessary until all the bolts remain tight. I normally need to repeat the torque sequence 4 times until all my intake bolts remain tightened.
http://ls1engines.com/tech/wp-conten...ads/intake.gif
BTW, did you double check to make sure the valley cover is pulled all the way down when tightened.?
Make sure knock sensor wires are not routed over high spots(bumps) on valley cover, and make sure the wires don't show signs of being pinched(flattened)..?
Yes I followed the torque sequence every time. I have access to GM service information (tech at dealership) and even doing the sequence it leaked. Yes the valley is all the way seated the knock sensor wires are out of the way i've even put putty down in areas to check if it was touching. I did check the intake and heads with a straight edge and there was no gap.
