MWC 9"/Strange Coilovers/Alumastars-RTS Combo
MWC 9" with backbrace and torque arm. Stock width. No abs or traction control. Yukon thru-bolt center section. Spool and 35 spline strange axles. 3.50 gears, Tow hooks, 3" 1/2 studs. Backing plates, Inverted shock mounts. Powder coated black Torque arm and cross member for t56 but is used for a th400 currently. Bmr xtreme drag bar black with all the brackets. Front and rear strange double adjustable coil overs with hypercoil springs and bearings.
the rear end NEEDS the coil overs because I had it made with out the spring perches.Less than 500 miles on these parts.
$4300 for everything listed obo
call or text 618-670-3839 I will ship. I take PayPal or federal money order.
Rear is still in the car, less than 500 miles on it. I will pull it and clean it up this week or when it is sold.
17"/15" Alumastars-RTS combo with tires.
17" weld polished alumastars and 15x10 weld polished rts.dumM and h front runners and 275/60R15 Hoosier drag radials. Less than 200 miles and 6 track passes on this set up. $2100 obo
are you willing do any trading on the wheels? i have a brand new set of TT2's 17x8.5 fronts and 17x11 rear brand new street tire front and mt 315 drag radials in the rear. just figure i might ask!
