Need brainstorm help in why car is rich, no changes in mods
Old 09-10-2013, 03:15 PM
SPRAYED 01's Avatar
Default Need brainstorm help in why car is rich, no changes in mods
So I had my car dyno tuned in February. It was tuned at 11.8afr from 10 to 19ish psi.
Now with no changed to anything,tune or mods my wb is reading 10.9 11.0.
Fuel pressure gauge in car reads the same.
Im going to rule out the wb hopefully tomorrow by trying a proven good one and il try another fuel pressure gauge too.
Other then that what could it be?
If my springs wore out causing valve float would that cause a rich or lean reading?
I tried swapping plugs and lowering gap from .028 to .023. No change.
It holds boost very steady and I checked for leaks.
Not sure on ethanol content at the time of the tune but i live in Chicago so it might have been a winter blend. Now its e10.
Thanks
Alex
Ps,in other threads i speak of installing a Meth kit. I turned that off and reverted to the non metg tune. This is straight 93 octane
Old 09-10-2013, 05:13 PM
Silver_TransAm's Avatar
The more ethanol in fuel the leaner car would be and more gasoline the richer fyi.
Old 09-10-2013, 05:15 PM
SPRAYED 01's Avatar
Ok that makes sense and further complicates things.
Old 09-11-2013, 11:32 AM
SPRAYED 01's Avatar
Ruled out wideband and fuel pressure today. As soon as it goes in pe even with little to no boost it goes to 11.0afr. Was 11.7 -11.8 before.
Im gOing to swap valve springs but i doubt that will do anything.
Old 09-11-2013, 12:13 PM
Verify map sensor. I once had an issue like that and a pin on the map was slightly corroded.
Old 09-11-2013, 02:08 PM
WheelsUp84z's Avatar
sticking/leaky injector? Faulty map.. O2's could be shot (if you're using them) causeing OL conditions.
Old 09-11-2013, 02:09 PM
SPRAYED 01's Avatar
I didn't give up on the meth but id like to figure this issue out before i add to the equAtion. I don't want to change the tune, there isnt a reason i should have to. That would be a bandiad type fix if there is a real issue
Old 09-11-2013, 02:32 PM
LS1Tech Sponsor
Slowhawk's Avatar
If you still run closed loop, that can change over to WOT. Main reason I keep my cars full open loop with turbo's.
Old 09-11-2013, 02:49 PM
SPRAYED 01's Avatar
How is that? Wot is open loop. Even it had closed loop that would switch over as soon as i go wot.
Old 09-11-2013, 02:52 PM
qqwqeqwrqwqtq's Avatar
LTFT's are disabled so no carryover into wot.
I would change the valvesprings as it seems you need them anyway by looking at the dyno graph. After that get it back on the dyno and check it out. (I think you will be wasting your time otherwise)
May have just been a discrepancy between widebands at the time.
Old 09-11-2013, 02:54 PM
SPRAYED 01's Avatar
Springs are getting done for sure, i have the install height checker and push rod length checker now. Just still seems odd for it to go so rich for no reason.
Old 09-11-2013, 04:35 PM
smokeshow's Avatar
Speed density?
Old 09-11-2013, 04:37 PM
SPRAYED 01's Avatar
Yes,3bar
Old 09-11-2013, 04:46 PM
smokeshow's Avatar
What was the temperature when you got it dyno tuned? February in Chicago is cold... Cold air is dense air, so it'll use more of the available fuel in the cylinder. The speed density model doesn't take temperature into account like a MAF will...
Old 09-11-2013, 05:08 PM
stevieturbo's Avatar
Check any air temperature compensations or any other compensations that may be applied
Check datalogs to see if injector pulsewidths are much different from before until now which would account for more fuel.
Valve float, or anything that would allow excess air into the exhaust would cause an apparent lean condition ( although it would not be lean )
However, in cases like this and where you have closed loop fuel control enabled, this false reading can end up adding more fuel creating all sorts of problems.
But check actual injector pulse widths. That will tell you if the ecu is opening the injector the same as before, or longer than before
Old 09-11-2013, 05:10 PM
SPRAYED 01's Avatar
True it is pretty hot here not and really humid. That very well could be it, I didn't think temp would make almost a point difference in afr. Maybe I should have a spring and summer tune.
Old 09-11-2013, 05:17 PM
You shouldnt need a different tune.
Air temp compensations should cover this.. Although I'm not a fan of following what physics would state. It's ok reducing fuel with temperature up to a point, but when charge temps get higher than desired, I'm quite happy for it to get rich again.
Either way, check actual injector pulsewidths. If these are the same as before, yet mixtures vastly different, something is up.
Assuming same boost levels etc etc
Old 09-11-2013, 05:26 PM
SPRAYED 01's Avatar
Ya I guess it cant hurt going richer when its hot out. I don't have any logs to compare injector pulse width from before.
Old 09-11-2013, 05:44 PM
smokeshow's Avatar
Injector pulse width would be a good way to figure it out. There is no method of compensating for air temperature without a MAF, so the AFR can be expected to change with temp in SD mode. Better rich than lean, though.
Old 09-11-2013, 06:02 PM
Nonsense, that's why you have a charge air temp sensor.
Quick Reply: Need brainstorm help in why car is rich, no changes in mods
