Which EGR wire to hook AEM Wideband to?
Are you talking about hooking the wideband signal wire to the EGR signal wire so you can read it through the PCM? If so, that guide tells you which wire to use.
The fuel pressure sensor lets you monitor your fuel pressure. I have a fuel pressure sensor mounted to the fuel rail and I use the EGR signal wire to read the fuel pressure sensor through the PCM and into EFILive when logging.
Heres a tutorial on how to do with with a fuel pressure sensor, wideband would be the same.
http://download.efilive.com/Tutorial...20Tutorial.pdf
