Project: 84' Blazer - LQ4/4L60e Swap
Old 09-13-2013, 11:18 AM
84blaze's Avatar
Default Project: 84' Blazer - LQ4/4L60e Swap
Hey guys,
I've been posting in the LSx section of S10forum but there isn't much help over there...
It's a 1984 S10 Blazer (Tahoe) with a 2.8L/700r4 that has become very tired and is in need of an LSx Swap!
Parts Bought:
KWik - Alt and PS bracket
Kwik - A/C mount w/ sanden compressor
Stainless Works - 1-7/8 LT Headers
CPW - Radiator w/Fans, Shroud & A/C Condenser
CPW - A/C condenser and lines
Shift Works: Mechanical Speedometer Kit Tailhousing
Holley LS Valve Covers - Black
Holley - 302-1 GM LS Retro-fit Aluminum Oil Pan
Parts to buy:
Fuel System - pump, regulator AN fittings
Lokar - Midnight Series Shifter
Rad Mounts from new S10
LS3 Dipstick/tube for Holley pan
Energy susp body mounts (Mine are all deteriorated)
Trans dipstick
Shiftworks tailhousing or Dakota digital gauges (To work with VSS)
Trans and Fuel lines 20ft of each with AN fittings
Steam vent hose.
Lokar 36" throttle cable
Ball joints
Hydroboost brake set up
PS pump pully with access holes
Type II Remote resivoir PS pump
02 Z28 Camaro A/C tensionner
Air filter
Oil, Coolant, Trans filter and fluid
Anyways, on to pictures!
What I started with:
Goodbye 2.8L
2001 6.0L LQ4 from a Suburban
When it was delivered:
Using a 4.8L dished flexplate to work with the 4L60e
4L60e
Old 09-13-2013, 11:25 AM
84blaze's Avatar
Parts!
CPW Radiator
Felpro gaskets
Stainless Works: 1-7/8 LT Headers
KWik A/C Bracket
KWik PS and Alt Bracket
Holley Retro Fit Pan
CPW Hood latch mod bracket
Suicudedoors.com LSx Swap DIY mount kit
CPW: A/C swap lines, compressor, and dryer
Old 09-13-2013, 11:31 AM
84blaze's Avatar
I got a lot done in the last couple weeks of August:
Rad in the core support
Ready for mock up!
Due to the way the S10 frames are I need to notch for the pan to clear. This is a patch panel I cut up:
I also had to notch the passenger side frame rail to allow more clearance for the LTs
Old 09-13-2013, 11:36 AM
84blaze's Avatar
Engine in with accessories:
Holes cut for A/C lines to run
Old 09-13-2013, 11:43 AM
84blaze's Avatar
Now you guys can see where I'm at after that big photo dump. I'm now at school until Christmas. I plan to put in a big order for the remaining parts I need to get this bitch running. I'm probably looking at another $2000 and $3000 in parts to get it going.
I want to keep all factory gauges, which is why I have that tailhousing or I may go with the Dakota Digital Gauges which are in my parts list. My main priority is to get the truck running and able to move under its own power by Xmas this year. Once that is done, I will work on the cosmetic touches, such as valve covers, tailhousing, A/C, trans rebuild etc... As the engine has about 120,000miles I wouldn't be surprised if I rebuild down the road, but like I said, the main priority is to get it running.
The truck is sitting at my parents place ATM and my Dad told me he would help prep the frame rails control arms, finish the notch, add tome exhaust cutouts in the stock trans crossmember and paint it all up before I get back in December. He also plans to tackle the wiring harness. If it is too difficult, I will buy a CPW harness.
I removed the engine and all front end components prior to leaving so it should all get cleaned up nicely. Sorry no pictures of this at this time...
Thats all for now.
Hopefully someone can answer some of my questions...
1- My transmission cooler lines are on the passenger side but the rad fittings are on the driver side. What is the best way to route these lines? I was going to route them over the trans and into the frame rail exiting where the fuel lines used to exit near the steering box. Should I run some flexible braided line and AN fittings for this as well, or is there a better material I should use?
2 - My plan is to run AN fittings and Russell ProClassic braided line from the break on the stock hard fuel lines (near forward leaf spring hanger). As I have "return style" fuel rails I will need to run about 20 feet of fuel line; 10 feet of feed and 10 to return.
Does anyone have any suggestions on what pump I should buy?
Do I need a fuel filter/regulator?
What else do I need for this system?
What size line should I purchase for feed? and for return? 6AN?
I would like to run an inline pump rather than an in tank pump. What's my best option for this?
3 - Are there any good sites that give a tutorial on how to create a wiring harness from the stock one?
Old 09-13-2013, 04:20 PM
snook's Avatar
Looks good. Just wondering why you had to notch the crossmember though? That's the whole point of the holley pan or muscle car pan, not having to notch it
Old 09-13-2013, 07:11 PM
LS1MCSS's Avatar
Get an intank Walbro 255 pump, just make sure it's not from ebay. Most of those are fake clones and won't last three months. You will need to make sure you have an inline filter somewhere. If you have the return style fuel rail, then it should have the regulator built into it. Post some close up pic's of the rail and we can see if you have the regulator.
Old 09-14-2013, 08:21 AM
84blaze's Avatar
It did technically "fit" with out the notch but I wanted to give myself some more room to run the brake lines and I would have had other header and steering clearance issues if I had mounted it in that rearward position. From what I've seen most S10's require a small notch with the Holley pan but some can get away without one.
Old 09-14-2013, 08:27 AM
84blaze's Avatar
I thought Walbro 255's were in tank pumps...?
Do you have a part number for the inline filter? I know WIX makes some for corvettes and camaros.
My fuel rails have have 2 lines coming off the intake.
Here are some photos. They are the best I have ATM (being across the country from it) of my fuel rails:
Hope you can tell me what exactly I need!
Old 09-14-2013, 08:26 PM
snook's Avatar
Oh Ok, I just moved my brake line out of the way. It is pretty tight on the gm pan too
Old 09-15-2013, 04:02 AM
Stormed_Norm's Avatar
If I had to do my swap over I would change the location of the a/c compressor and knotch the fram and move it down to the factory location and keep the factory brackets. With the rad hose there it just seems so crowded, and it allows for more room up top. But nice job otherwise. I like those white bricks. ( 1st gen s series)
Old 09-18-2013, 12:28 PM
84blaze's Avatar
I plan to make new front lines to follow the contour of the notch and to get the "T" fitting out of the drain plugs way.
Old 09-18-2013, 12:29 PM
84blaze's Avatar
Thanks! I hope I wont have too much difficulty with finding a upper rad hose to fit.
Can't wait till its all put together!
Old 09-18-2013, 12:50 PM
84blaze's Avatar
Still need fuel system help...!
Old 09-18-2013, 03:31 PM
406chvycamaro's Avatar
What question do you have on your fuel system?
Old 09-18-2013, 06:22 PM
84blaze's Avatar
What filter and what pump should I run?
Can I wire the fuel pump into the harness or do I need a stand alone?
Old 09-19-2013, 01:39 AM
loweredd's Avatar
Let the ecm control the fuel pump relay. Cheap and easy. WIX #33737 fuel filter/regulator. ~$32 on ebay.
On the transmission lines, I would run them to the core support and over to the other side from that point.
Old 09-19-2013, 08:52 AM
ctd450's Avatar
The engine already has a pressure regulator on the fuel rail. Pick up a Walbro 255, it can be mounted on the frame or in the tank. For filters, you need 100 microns before the pump (a pickup sock is fine) and 10 microns after the filter. Summit and Jeg's both have serviceable inline filters for a reasonable price. Run -6 lines supply and return.
Old 10-06-2013, 06:14 PM
84blaze's Avatar
I ordered some parts:
Random Orders
Rock Auto: Spectra tank (GM18B) and Spectra sending unit (FG03A)
eBay: EGR billet block off
KWiK Performance: Type II PS pump/pulley/reservoir,
eBay: Dorman 924-424 rad bushings,
eBay: Hydroboost S10 mounting plate,
Amazon: 2 - LS Swap Books
GM LS-Series Engines GM LS-Series Engines
SA Publications SA Publications
Summit Order:
Holley Aluminum LS Valve Covers X1
Lokar Midnight Series Throttle Cable - 36" X1
Billet Specialities radiator cap X1
Dakota Digital Gauges X1
Energy Suspension Body mount kit X1
Chevrolet Performance Drive Belt Tensioner - Z28 X1
Fuel System:
Edelbrock In-tank fuel pump X1
Fram inline filter X1
Russell ProClassic -6AN hose - 50ft X1
Fittings:
Russell - 6 AN Hose to Female -6 AN X6
Fragola - Male -6 AN to 16mm x 1.5 Male X2
Russell - M14 x 1.5 to -6AN Flare X1
Russell - M16 x 1.5 to -6AN Flare X1
Russell - Push on EFI fitting - 5/16 X1
Russell - Push on EFI fitting - 3/8 X1
Exhaust:
Summit Racing® Universal X-Pipe Kit - Stainless Steel X1
Pypes SS V-Bands X2
Once all these parts come in I should be able to get this thing going by Christmas!
Old 11-17-2013, 10:45 AM
84blaze's Avatar
On with the pictures!
Some Mr Gasket -6AN straight and 90* as well as some Russell Transmission fittings:
Billet EGR block off:
Dorman rad bushings:
Hydroboost S10 firewall mounting plate:
GM LS3 dipstick and tube:
LS Swap books:
More parts:
While I'm away at school my Dad has been busy doing the dirty work for me.
He's managed to finish welding the oil pan and header notches while also grind down and somewhat smooth out the front frame rails.
Here are some pictures.
Some pictures of the firewall that needs to be beat un to clean the SW LTs:
Ill be home in 3 weeks and then the progress will be almost daily. Once I get home I'll have 30 days to complete the project. Hopefully I'll be able to get it running by then!
More photos to follow.
Quick Reply: Project: 84' Blazer - LQ4/4L60e Swap
