Clutch problems
Clutch problems
Couple days ago while sitting at a light I noticed while the clutch was pushed in, the car was trying to roll. I put it in neutral and pumped the pedal. This helped enough to get it home, and I had 15 min of lights and what not shifting to do. I had no sign the clutch was going out.
Got the wife to help with her pumping the clutch pedal, and I was using CarQuest's version Mighty Vac. Did alot of reading for 2 days on ls1tec but only got just a tiny amount of bubbles. Yes the fluid was dark!
Now there isn't any gear to get into so whatever I had is now gone. I purchased from CarQuest just the clutch master cylinder this morning. Car is all jacked up to work on all this coming week by myself. I plan on going with the Tick, later.
I have watched The Blue Knights video and others and have and still reading about it.
My question is, is it still possible I have air trapped, even tho I didn't do it at the bleeder screw on the tranny. It seems that everything I have read it ends up being the clutch master cylinder. Thanks for any help
The spring would not normally cause an issue with release when the pedal is depressed. This sounds more hydraulic in nature. Check the fluid. Is it dark or discolored? Have you tried bleeding the system? If not, flush and refill as the starting point and got from that point forward. Let me know what result you see. Thanks,
I'm already in the process of pulling the stock one out. It's unhooked from the transmission, but the 2 star washers that are underneath the alum u shape that holds the 2 bolts to the master inside where the pedal is, seem to have been put on backwards! They are not on top of the u shape alum piece that's attached to the clutch pedal. They are under that piece! Now I'm stuck
How do I get to them without prying the hell out of that alum piece?
Thanks, but as I put in the above post, Fluid was changed out allready, fluid is dark, I did the bleeding with the Mighty Vac tool.Search says I don't need the spring. Some went thru the hell to put it back on but pretty much says don't worry about it. And I'm not.
Thank you, I started doing that by means of pulling the clutch pedal back up, and it comes off about half the distance of the bolt or stud whatever it is. That's when another one of those tension springs came off Now I know I'm screwed! I started reading post about the guys finding 1 of these springs broke, but now I have 2.
I was intending to check on the fluid condition after your flush and fill. If the darkness and discoloration have returned it can evidence heat or break-down within one of the cylinders which will affect function. If the pedal/clevis/master mechanism is not assembled properly this will inherently affect function too.
Yes, and this was done at the assembly line where the car was put together. I got the hawk with 300 miles on it, and I know the clutch was never touched. I just hope everything works right when I'm done. Hopefully by Sunday Ill post it's fixed.
Well the new clutch master cylinder got installed, and we pumped and pumped and pumped to make sure there was no air. So that didn't fix it. Getting everything drained and apart to pull the tranny out New GM slave has been ordered from a sponsor. At least I can change the tranmission fluid now a whole lot easier.
