Holley HP Leaning Fuel? How lean can I go.
Old 09-22-2013, 09:17 AM
donnie_19's Avatar
Default Holley HP Leaning Fuel? How lean can I go.
Trying to fine tune to get better fuel mileage. LS LQ9 with cam and a2004R OD tranny. At 70 mph rpm is 1900 or so. Only getting about 16 mpg. Seems it should be much better. I have changed the A/F table to 14.7 in the cruising range. How much leaner is safe?
Timing is around 28.5 in the same cruising range.
Old 09-22-2013, 04:46 PM
LSX Power Tuning's Avatar
Every combo is different, but all your factory stuff is 14.7. You'll have to try each a/f ratio and see if one nets better mileage. I start at 14.7, then 14.8,14.9 etc. Have you tried more timing in the cells where its cruising in. 28.5 seems a little low for cruise. I would try a little more timing first then try leaning it out.
Old 09-26-2013, 04:33 PM
donnie_19's Avatar
Here are my fuel map and spark currently. Getting around 16 mpg with my foot in it city/highway. Rear end is 308 with the 2004R tranny OD is .67. Cruising at 70 mph tach is reading between 1800 and 1900 rpm.
Old 09-26-2013, 11:26 PM
If you email me your tune I'll make a couple changes for you try. Email is in sig below.
Old 09-27-2013, 02:10 PM
donnie_19's Avatar
sent an email to info @ from donpetstop
Old 10-04-2013, 07:15 AM
donnie_19's Avatar
Advanced the timing one degree in the cruising range. The gas mileage was slightly improved to 16.5. Thats combo city highway. Will adjust the A/F.
Old 10-04-2013, 10:56 AM
Try adding 1 more degree in the light cruise cells.
Old 10-06-2013, 07:10 AM
samdogmx's Avatar
do you have the decel fuel cutoff enabled? if not that might help
Old 10-07-2013, 06:13 AM
Old Geezer's Avatar
Any engine mods?
Old 10-08-2013, 07:08 AM
donnie_19's Avatar
I will double check the decel fuel cut enabled but I think its checked off. My last MPG with mild city and some highway was 16.7 mpg.
Some mods, Bullet cam, 42 lb injectors. Bored .030 over, 241 heads decked.
Quick Reply: Holley HP Leaning Fuel? How lean can I go.
