wtb LS6 or BBK intake
Bbk intake will make your car run hot don't let looks fool ya dats y they off da market it's aluminum not plastic ls6 will b your better choice don't hurt yourself or pockets I seen it happen 4 times
They are pretty equal as far as flow numbers, from what I've read, but the BBK offers better power* on the top end.
The myth about heat soak is just that, a myth. The air moves fast through the intake, through the hot heads, and into the hot chamber. The aluminum intake being a bit warmer than a synthetic one isn't going to make a difference.
and a few link to previous owner and other stating some good info
https://ls1tech.com/forums/advanced-...heat-soak.html
https://ls1tech.com/forums/generatio...s6-intake.html
