Advanced Engineering Tech For the more hardcore LS1TECH residents
heat soak
Old May 20, 2010 | 05:29 PM
garygnu's Avatar
Default heat soak
dose a aluminum intake like a bbk incur heat soak,and effect power levels?
Old May 20, 2010 | 05:34 PM
ttranssam's Avatar
you should of done a search...yes/no is it worth it....NO but if your scared of a nitrous backfire then get it. sooooooo many ppl with it says its good soooooooooo many ppl also say hell no. if i were you stick with a ls6 intake, they make more power
Old May 20, 2010 | 09:36 PM
garygnu's Avatar
I have a fast already.I feel a cast aluminum intake being porous will absorb heat from the heads and retain it.I read where people have seen some power drops after a few pulls.I hear a few people that say this is a myth.
Old May 22, 2010 | 05:56 PM
Arc00TA's Avatar
Its a myth. Aluminum intakes have been on cars for far longer than plastic ones and have never had any issues. Looking at a BBK, the intake does not even sit on the heads. It sits on gaskets, so there is no metal to metal contact to begin with.
For the record, I have gone from LS6 to a BBK and felt a SOTP gain. I also ran my bbk at the track last night, and the car pulled just the same at pass 20 as it did on pass 2, and I never once let the car cool in between. I made 22 passes and the last few were actually the fastest.
Old May 22, 2010 | 10:27 PM
garygnu's Avatar
the alum intakes have great runner design.did you make a run with the engine stone cold?the engine and intake came up to max temp quickly ,the intake temp between the 1 run and the last run was probably the same .the intake dose not need to touch the head to absorb heat.has any one used a temp gun and pointed it at a intake before and during testing? could the air temp and air density have improve towards the end of you day at the track?the alum intake has more mass,I feel it will retain more heat longer.which intake will cool down faster?
Old May 22, 2010 | 10:44 PM
NemeSS's Avatar
the nylon intakes will never retain as much heat as a casting.
ive owned the lpe/holley intake and improved performnce significantly over the stock ls1 manifold it replaced. sure it was hotter to the touch after hard runs or continuous street time.
Old May 22, 2010 | 11:28 PM
Arc00TA's Avatar
Okay, the horse is beat but lets give it one more whack. Here we go:
Will the aluminum intake be hotter on average? Yes.
Will it make a difference and/or cause you to notice loss of power? No.
Get the one you like. If you want to run nitrous and feel you need a metal one, go for it. The difference of power from the beaten-to-death heat soak is probably far less than the amount of power it would take to move the extra 10 lbs of metal intake, which is to say you won't notice a thing. I keep seeing these threads where people act like an aluminum intake is going to cause them to loose 100hp as soon as the car gets up to temp, and I was trying to show you based on my experience at the track with it that I didn't suffer any losses. I drove 40 minutes to the track, tech'd, ran 22 runs back to back, and went home. Oh, and when I got home I could touch my intake manifold just fine, just like a plastic one.
Old May 23, 2010 | 01:11 AM
garygnu's Avatar
the most a alum intake will lose is 5-10 hp when warmed up,wanted to hear other peoples thoughts on this subject.would your car make more power if your first pull was when the intake was stone could?I feel if a person can get a alum intake for under $300 ,it is a good deal.has any one used a temp gun to test a ls1 intake alum or plastic during a dyno pull?I already have a intake .I hear things and like to find out if they are true or not.
Old May 23, 2010 | 03:16 AM
Arc00TA's Avatar
Do you have proof of that loss? I'm curious to see it. Also, if I can find one of those infrared temp guns I will take the temp of my intake a couple of times after different driving conditions and post it up.
Old May 23, 2010 | 10:00 AM
garygnu's Avatar
if the intake was stone cold the air moving through the intake would be cooler.when the intake warms up the air will be warmer.it would be interesting to check the temp of a plastic intake also ,to see if they retain some heat.would E-85 help a alum intake make more power.
Old May 29, 2010 | 03:21 AM
Bobsmyuncle's Avatar
not true. at all. at wot, the air moving through any intake, is moving plenty fast enough to not have time to warm up the air. it would be interesting to see what actual mph the air is moving thru the intake runner.
Old Jun 4, 2010 | 08:46 PM
Paint_It_Black's Avatar
The air moves through the hot cylinder head too.. I don't hear people bitching about heat soak from their cylinder heads..
Old Jun 8, 2010 | 09:44 AM
bww3588's Avatar
https://ls1tech.com/forums/general-l...um-intake.html
had to....
Old Jun 15, 2010 | 02:20 AM
Arc00TA's Avatar
Alright, does anyone have a suggestion on how to go about recording some data about this? I have a BBK on my car now, and I have an LS6 in the garage that can go on. If I can figure out what to do, I can take temps and such and post ACTUAL RESULTS, not hearsay and guesstimates. I'm thinking use one of those infrared sensors to take the outside temp, and then maybe one of those flat heat probes you use on computer parts to put inside the manifold if I can figure out how to secure it so take the inside temp? Any suggestions? I am really curious about it now so I think I will do the legwork and find out the answers.
Old Jun 15, 2010 | 03:25 AM
Soul TKR's Avatar
FALSE!!!!
I've actually seen back to back dyno's of the BBK making more than the LS6
FACTS:
The BBK WILL be hotter than the LS6. When living in Phoenix for the past 2 years I could probably boil an egg on my BBK. Half of that could attribute to the 120 degree heat outside as well. Living in one of the hottest areas in the US I can attest to say that I noticed NO difference in the way the car performed on a cold start to what it performed like after a full day of driving around.
Heat Soak? Yes the intake gets hot as ****, it's metal... does it hurt your performance? I vote no, seeing as pretty much all top performing race cars use metal intakes. I have yet to see any proof of heat soak being a true theory. I haven't noticed any performance loss what so ever. Most people jump on the badwagon and yell "Heat Soak" without having any personal experience or proof to back up their claim.
It makes more power than the LS6, and is great for boost or nitrous while also allowing porting options. The ONLY downside I see over the LS6 is the weight difference. But unless your building an all out drag car where every little itty bitty pound counts then I don't see that being a problem.
Old Jul 6, 2010 | 09:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I think what people are getting away from when they say "FAST" cars is that most "FAST" cars are not really and truely street driving, or daily driven.
Heat Soak is most certainly an issue. Getting that IAT as low as it can be does make more power. FI guys always have to fight this fact. But N/A guys it does not seem to make a difference once the intake is hot.
What I will say is this past weekend I had to fix a vaccume leak on my LS6 intake. I decided for the fun of it run a scanner and let the car go from dead cold ambient temp of roughly 72 Degrees (the car was in the garage), The IAT read the same temp. Just simply starting the motor to allow the car to get the coolant to temp the IAT's increased as well.
By the time the car got to closed loop I was watching real time the IAT creeping up to over 90. The car had a SLP LID, stock P/P TB and a un modified LS6.
Having owned High COMP LT1's there was certainly a difference at the track if I iced the crap out of the intake and basically pushed to the line and started it at the last possible moment.
So as a thought piece I throw it out there that as much as people say heat soak is not an issue I say that on a street driven car it does matter. There are gimmicks out there like the bag you can strap to the motor and put in ICE cold gel packets and have been proven to gain a tenth or 2.
I choose not to run one as it does not reflect real street useage but if you needed to gain a tenth, thats a trick you can use.
One other point to make about heat soak is that for bracket racing, a car that was ALWAYS hot tend to be consistant. They may not break any PB times but I have won a few events because I did not let the car cool down regardless of the ambient temp or DA. For Fuel Injected cars it can make a diff.
Old Jul 6, 2010 | 12:35 PM
jimmyblue's Avatar
Moderator
Sure, the aluminum will rise to underhood air temp at
low airflows.
The relevant question is, how much will that hot intake
raise the air temp as it slides on through at something
like 700 ft/sec (or spending about 3mSec in the oven)
at high RPM WOT.
Qualitatively I'd say, "not much". Some thermodynamics
expert wants to put better numbers to it, please do.
Old Jul 7, 2010 | 02:13 AM
chuntington101's Avatar
Actually some people coat the insides of the intake and exhaust ports to stop heat absorbtion to and from the head......
Old Jul 7, 2010 | 06:32 AM
bww3588's Avatar
who? old school hot rodders that beleive everything they hear?
Old Jul 8, 2010 | 03:21 AM
i have seen a few builds that are doing it. in theory it should make a difference, esp on the exhaust side. however i haven't see any back to back testing. so i guess you cant prove or disprove the idea!
