Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Good timing curve for msd 6012?
Old 09-26-2013, 09:57 AM
Zia_Boy's Avatar
Default Good timing curve for msd 6012?
Have 408 stroker 678 lift cam solid roller 317 ported and polish heads 850 holley carb 411 gears 28" tall tire. Need help on a good timing curve before I take it to tuner and dyno. Want to take to track to see how I run like it is.. Also going to shoot a 150 nitrous after I get a good on motor run.
Old 09-26-2013, 05:27 PM
In-Zane Moderator
ZONES89RS's Avatar
With no info for compression, try 18 at 0, ramp all in to 32 by 2000 across the board.
Old 09-26-2013, 05:32 PM
TXsilverado's Avatar
what compression are you running and what octane fuel are you planning.
Old 09-27-2013, 01:27 PM
Zia_Boy's Avatar
11.1 compression
110 octane
Old 09-27-2013, 01:28 PM
Zia_Boy's Avatar
11.1
110 octane
Old 09-27-2013, 08:19 PM
Doug G's Avatar
I wouldn't think the 6012 would be any different than the 6010 box as for timing...just how it gets its reading (24 Vs 58 wheels).
The sticky at the top of the page should help.
Old 09-27-2013, 10:29 PM
In-Zane Moderator
ZONES89RS's Avatar
That's what I assumed would be 11:1. 32 max will be fine and tune out from there.
Old 09-29-2013, 04:20 PM
Zia_Boy's Avatar
Thanks for all the info.
Old 10-01-2013, 03:31 PM
Zia_Boy's Avatar
I put the 18 on 0 and 32 on 2000 all the way cross the board and it said timing was at 38 degrees. Will that be correct?
Old 10-01-2013, 03:41 PM
Pop N Wood's Avatar
Do you have a MAP sensor hooked up? If not, zero out the MAP timing otherwise it will always be at 0 PSI and add that amount of timing.
Old 10-01-2013, 04:43 PM
Zia_Boy's Avatar
No map sensor isn't hooked up. So when I zero it out what should it say?
Old 10-01-2013, 04:44 PM
In-Zane Moderator
ZONES89RS's Avatar
It should be locked in wherever you set the tune with the map zeroed.
Old 10-02-2013, 06:38 AM
Pop N Wood's Avatar
As per the instructions a 6012 box will adds 20° of vacuum advance when the manifold pressure is between 0 PSI and 4 PSI. Your picture shows your MAP is reading 1.1 PSI pressure, so yeah, 18° "mechanical" plus 20° vacuum adds up to 38° total. Unless you live in Denver it looks like your motor is drawing a good 28 inches of vac at idle.
http://www.jegs.com/InstallationInst...1/121-6012.pdf
This is pretty interesting. Look at the pill curves in Figure 4 of the 6012 instructions and they are way different than the ones for the 6010 box. The 6010 box has the majority of the advance coming from the mechanical part (RPM based) with just a touch of vacuum advance while the 6012 has much less mechanical advance and beaucoup vacuum advance.
http://www.jegs.com/InstallationInst...1/121-6010.pdf
We should probably cut and paste the default timing figures for the two boxes into zone's sticky post.
Old 10-02-2013, 10:54 AM
Zia_Boy's Avatar
-------yea it's my first time playing with box. Map sensor isn't hooked up so I'm going to 0 it out and I'm hoping it show 32 like it suppose to. Thanks for the info
Quick Reply: Good timing curve for msd 6012?
