A4 to T56 swap: Pedal wiring Help
Hello, i just finished up the mechanical side of my A4 to T56 swap on my LS1 Z28. Now i am working on the wiring and i need some help. The pedal assembly
I believe may be from a v6 manual, but I'm not sure. I am not good with wiring so any help is greatly appreciated. Thanks in advance.
1) The Clutch Pledal Position Sensor has two wire, green and purple/white. I connected the purple/white to C200B/D, but i cant seem to find out where the green wire connects to.
2) The Cruise Control Clutch Switch has 4 wires: brown/white, pink, gray, and black/white. The brown/white, and pink i connected to the existing harness, but i cant seem to find out there to connect the gray and black wire. I believe it connects to C220 on passenger side (where engine harness connects to body harness).
no offense man but please try a search this has been done many times sorry... refer to my writeup its all in there
https://ls1tech.com/forums/manual-tr...e-writeup.html
