msd 6010 cam sensor will not plug in
I have a 6010 on a ls2.. ive swapped outer wires and went to plug the connector in and it does not fit. Anyone else ran into this
thanks
thanks
the 24 and 58 wheel sensors do have different sized cam sensor connectors.
Also make 100% sure you aren't mixing up the cam and crank sensor. I had that issue when I initially tried to hook a 6010 box to my 58X wheel motor. They moved the sombeaches when they went to the new motor so make sure the harness is right.
Ok figured out what was wrong.. I bought a cam cover with the cam sensor. My cover had a harness that plugged into the sensor and went to the bottom of cover.. the msd 6010 will not plug into it because its a ls2 etc setup. If you unplug the harness from the cam sensor and plug the msd right into the cam sensor it goes right in.
