manual rack and relocated alternator
Old 09-29-2013, 07:12 PM
98Camarod's Avatar
Default manual rack and relocated alternator
For those of you that have a manual rack and relocated the alternator to the passenger head, what did you do to route the belt back around?
I'm thinking getting a 6 ribbed idler and put it on the stock idler bracket, but I don't know if that will be enough angle for the water pump.
I'm open to ideas
Old 09-29-2013, 08:28 PM
ws602's Avatar
I have a manual rack but alt is in the stock place I moved my idler pulley to the d/s head it's the first time it's been done this way :-)
Old 10-01-2013, 12:19 PM
98Camarod's Avatar
Anyone else?
Old 10-01-2013, 05:03 PM
Doobie52's Avatar
This is the best picture I could find of my setup. Works great. No cooling issues and I've gone as fast as 127 in the 1/4 and no problems blowing the belt off.
Attached Thumbnails manual rack and relocated alternator-photo-oct-01-2-59-05-pm.jpg
Old 10-01-2013, 06:41 PM
98Camarod's Avatar
Is that the tensioner with a smooth pulley?
Old 10-01-2013, 08:13 PM
Doobie52's Avatar
No, it's the CBR alternator relocation which eliminates the tensioner all together. The alternator becomes your tensioner with the setup. I added another pulley to put some more tension on the belt.
Old 10-01-2013, 08:30 PM
ss performance's Avatar
I have been thinking about going to a manual rack.
What rack did you choose and how is it to drive on the street?
Thanks
Craig
Old 10-02-2013, 12:25 AM
Doobie52's Avatar
Rackdoctor depowered manual rack. Works great on the street.
Old 10-02-2013, 04:33 PM
1fast bird's Avatar
When I had my car, I didn't have power steering either. I used a manual tensioner on the drivers side head with the alternator on the pass. head, and it seemed to work fine.
Old 10-02-2013, 07:34 PM
98Camarod's Avatar
Do you remember what tensioner it was?
Old 10-02-2013, 09:19 PM
Orange99Z's Avatar
I solid mounted the alt & used the stock tensioner routed belt like Doobie52. No cooling issues either. Went 129 mph in qtr & 6800 rpm, didn't throw belt.
Old 10-03-2013, 06:55 PM
1fast bird's Avatar
It's a Comp cams tensioner that looks similar to the Katech. You will probably need an assortment of washers to space it correctly but it works great. That was the only way I could see getting enough belt wrap. I wouldn't trust having the water pump run like the ones above.
Quick Reply: manual rack and relocated alternator
