92 Mustang swap
Old 09-30-2013, 11:06 AM
ion05's Avatar
Default 92 Mustang swap
Currently have 92 Mustang with the following parts, ls1 engine, 4L60 Auto trans
AJE k memeber, transmission crossmemeber,engine mounds, A arm with coil over kit.
Was wondering what you all would recommend for the rear? and spline? as well as Harness?
Was planing on keeping it NA no boost or turbo
Old 09-30-2013, 03:17 PM
23_hellfox_23's Avatar
Just use an 8.8 out of a GT fox and build it out.
31 spline axles are the way to go if you'll be N/A, get some killer gears for that thing!!!
They sell stand alone harness' for that swap or you have whatever harness on the motor modded to be stand alone which from my understand isn't the hardest thing in the world.
AJE also has rear tubular control arms that would be good to get ahold of.
TeamZ also sells a custom built rear end you can order from them.
I'm going to be in the process of the same build before to long in a notch, good luck!
Old 09-30-2013, 05:11 PM
ion05's Avatar
http://www.americanmuscle.com/31spli...8693-4lug.html
Would that work? or am i better off picking up the 8.8 rear end off a junkyard?
Old 09-30-2013, 05:14 PM
ion05's Avatar
What about driveshafts? and companys you can recommend or pull from a junkyard?
Old 10-01-2013, 11:28 AM
That would be a good kit to pick up!
You can probably piece it together for a little cheaper might look into that.
As for the driveshaft I would imagine http://www.driveshaftshop.com/ would be a good place to start.
Old 10-01-2013, 11:33 AM
Also N/a is great and all, but boost is the best!
Get a 5.3 and throw a turbo on that thing and you'll make considerably more power than n/a on an LS1 for about the same cost! (personal opinion)
Or just spray the **** out of a 5.3 and you'll make a lot more power!
Old 10-01-2013, 12:33 PM
ion05's Avatar
I ended up picking up a 5.3 LQ4 going to swich out the oil pan cuz it hangs way too low. Thanks for your input
Old 10-01-2013, 01:16 PM
Awesome!
Post up some pictures of your car!
LQ4 is perfect for boost that iron block can handle plenty!
Old 10-01-2013, 03:20 PM
kevin99hoss's Avatar
just an FYI an LQ4 would be a iron block 6.0, the 5.3 is most likely an lm7. There should be a stamp on the back of the block with 4.8/5.3 or 6.0.
Old 10-08-2013, 01:42 AM
ion05's Avatar
decided geting the lm7 motor 5.3 but need a complere wireing harness or stand alone system and suggestiom,
Old 10-08-2013, 08:14 AM
http://secure.ultracart.com/catalog/PSI/PCM-1003.html
This site does the stand alone harness!
Old 10-09-2013, 10:23 AM
ion05's Avatar
Thanks for the link
Old 10-09-2013, 11:32 AM
Let's get some pictures of this thing!
Old 10-09-2013, 04:44 PM
ion05's Avatar
https://ls1tech.com/forums/conversio...-lm7-swap.htmli have a build thread started already lol
Old 10-09-2013, 05:15 PM
Ah okay I didn't realize haha.
Quick Reply: 92 Mustang swap
