MAP 04-07 CTS-V Trailing Arms, More Rubber...Again!
Old 10-01-2013, 11:34 AM
Closed ex-Sponsor Account
maperformance's Avatar
Default MAP 04-07 CTS-V Trailing Arms, More Rubber...Again!
Based on recent demand we have decided to make another batch of our CTS-V trailing arms! General consensus seems to be that these trailing arms allow up to a 295 or 305 rear tire with 10" rims. Anything larger than that and you're looking at spacers and/or modifications to other components, please check out the tire size discussion threads below for additional information.
OEM Trailing Arm:
MAP Trailing Arm:
Full Disclosure: Development of these arms was done quite some time ago by a former MAP employee. We will try to answer fitment questions, etc. to the best of our abilities, but we we make no claims of being CTS-V wheel and tire experts Here are some resources from the previous group buy that may be of assistance:
MAP Trailing Arm Installation Guide
Installation tip: Filing the shock mount
Tire Size Discussion Threads:
http://www.cadillacforums.com/forums...ml#post2168996
http://www.cadillacforums.com/forums...ml#post2169312
http://www.cadillacforums.com/forums...ml#post2519720
Old 10-01-2013, 03:13 PM
punishmentcycle's Avatar
300!!! hope that includes dinner and a movie
Old 10-02-2013, 05:26 PM
Correct me if I'm wrong, but didn't you pay at least $325 for yours in the Creative Steel group buy? Did he provide dinner and a movie?
To the top!
Old 10-04-2013, 12:32 PM
Bump!
Old 10-07-2013, 10:45 AM
Almost ready for nickel plating!
Old 10-14-2013, 11:26 AM
Being plated now guys!
Old 10-17-2013, 10:12 AM
Turned out pretty slick
Old 10-17-2013, 09:28 PM
jmargo's Avatar
Have you done any changes to the original to prevent the front bracket from separating at the weld ?
Old 10-18-2013, 10:44 AM
Our fabrication team has improved vastly so the fitting of the tube to the flex joint has a much nicer contour with additional surface area, not to mention the weld quality is second to none.
Old 10-18-2013, 11:55 AM
jmargo's Avatar
Thanks for the info.
Old 10-21-2013, 09:56 AM
Detailed images are now up on our website!
Old 10-28-2013, 11:43 AM
Bump!
Old 11-19-2013, 06:20 PM
Submit your car to our "customer rides" section to get entered into monthly giveaways and possible be highlighted on our Facebook Fan page!
Old 11-19-2013, 10:09 PM
Toxic-Evo's Avatar
these are pretty bad ***.... bump for a pretty sick set up. is it poly or what in the joint?
Old 11-20-2013, 06:06 PM
The Joint is a very beefy pillow ball for a very ridgid fit so you wont start rubbing over time. There is also a zerk to grease them aswell.
Old 11-22-2013, 11:35 AM
Toxic-Evo's Avatar
very nice... if i can ask is it UMI's joint... or more like a Johnny joint?
Old 11-25-2013, 11:14 AM
It uses Delrin bearing races and a chromed spherical bearing which is supposely much stronger than other poly style races
Old 11-27-2013, 06:44 PM
Submit your car to our "customer rides" section to get entered into monthly giveaways and possibly be highlighted on our Facebook Fan page!
Old 12-02-2013, 03:02 PM
Bump!
Old 12-04-2013, 06:13 PM
Quick Reply: MAP 04-07 CTS-V Trailing Arms, More Rubber...Again!
