3th Gear, high rpm shifting issues
I have 2002 SS with ceramic coated headers and high rpm shifting issues.
I got on it on up to 4th gear and all was good until my 3-4 shift. It got difficult but went into gear. After that it acts like it is slipping toward the top of 4th(no slip in lower gears) and I got a STIFF clutch pedal. I think I still have a fluid boil issue.
I wrapped my clutch line with header wrap and heater hose outside that. I have a tick master and fresh ATE Super blue inside.
With normal driving everything feels just fine.
Slave, master, and clutch all have about 30,000 miles on them.
I think I need some better clutch fluid in there.
Car finally broke down. I lost fluid in the master cylinder reservoir so I know I have a hydraulic leak. My Tick MC has 34k on it and the same for the SC. I'm thinking the SC is what blew. I seem to keep having hydraulic issues every 34k-40k miles. I'm wondering if my pressure plate is getting weak around that time too.
This issue of low clutch and/or hydraulics life seems to happen with stock mc's and the tick mc.
I was using a southbend 638lb/ft clutch for my 362rwtq car. This might have been part of the problem.
My adjustment on my tick mc... It seems like it sits just a little above the brake pedal.
The way I adjusted it is car running, clutch in and held, shift to 1st while still holding clutch pedal to floor, rev to 4500-5000rpm and hold. If I noticed the car moving forward while on a flat surface, then adjust the pedal out half a turn.
I feel like I found that fine line because I stopped on the exact half turn that stopped the car from moving. Also, I noticed my clutch fluid stayed clean after that. Before the change in turns on the pedal, the fluid would get DARK quickly.
The clutch pedal being just a bit higher than the brake pedal seems to be the concensus across the board for what most people have it set to across the forums, myself included. I can't imagine you having fluid boiling issues, especially with having the Tick hydraulic line, wrapped, and Super blue fluid. Usually the clutch pedal gets soft/spongey on people. I don't think I can remember anyone ever saying the pedal getting stiff on them.
