VR SinisTTer - 195mph half, 1586-rwhp, Twin Turbo STREET C6!
Old 10-07-2013, 02:46 PM
David@Vengeance's Avatar
Thumbs up VR SinisTTer - 195mph half, 1586-rwhp, Twin Turbo STREET C6!
Where do we even begin… Well, let’s start from the top end of the half-mile track and work our way backwards. What you’re looking at here is our latest twin turbo creation, SinisTTer, which ran 195 miles an hour at the Wanna GO FAST half-mile event, made just over 1580-rwhp on 23psi, and is street driven, Vengeance Racing approved, and flat out wicked. But, of course, things didn’t start this way…
“I had decided I had wanted more out of my blown LS2 and figured if I was going to build the motor I should put more power down and caught a decent deal on a used TTiX kit. I had the goal to hit 200mph in a mile event and wanted a car I could drive for pleasure, be fast and still look the part. I emailed this vision to eight shops, all who I have seen put out 1000rwhp Corvettes here on the forum. I heard back from four of the shops that they would put together a quote for me to get an idea of what it would take to achieve my goals. From here only two actually made me a quote and after reviewing what I would be getting for my money I went with Vengeance. The Vengeance experience began right away...” And once it began, there was no stopping it!
Obviously, the stock motor is long gone, and what we built for Mike was an aggressive street motor stuffed with race car quality parts. An RHS block houses a Callies Dragon Slayer crankshaft, a set of Callies Ultra Billet rods, and a set of Diamond custom pistons. Calico coated main and rod bearings, coated cam bearings, double hard anodized pistons… you get the idea. 441 cubic-inches of fortification topped with a set of 287cc RHS LS7 cylinder heads, T&D shaft mount rockers, and a custom Vengeance Racing solid roller camshaft. No, you can’t have the specs
Engine:
RHS Block, 4.125-inch bore
Callies Dragon Slayer crankshaft, 4.125-inch stroke
Callies Ultra Billet connecting rods, 6.125-inch length
Diamond custom spec pistons, 4.125-inches
Calico coated main & rod bearings
Coated camshaft bearings
Fully Machined to Vengeance Racing specification
Custom Solid Roller Camshaft, Vengeance Racing specification
Morel Ultimate Pro solid lifters
Cloyes timing set with C5R timing chain
Melling oil pump
ARP LSX 6-bolt stud kit
ARP camshaft bolts
RHS 287cc LS7 6-bolt cylinder heads, Titanium intake valves, Inconel exhaust valves
PAC Racing 1225 dual spring kit with Titanium retainers
T&D Shaft Mount adjustable rocker arm system
ATI SFI Damper
Assembled by Vengeance Racing
Now, for most people, a solid roller 440 would be plenty for the street and more than enough for the track but, well, we’re not most people! Which meant we needed to break out the TIG welder and put our in house fabricator, Jey Clegg, to work. And after Mike told us that we “needed” to put the turbochargers where the gas tanks belonged, we knew we were in for a serious build. That’s right, the two Comp C43 72/75 oil-less turbochargers had to fit in the rear quarters of SinisTTer, and the downpipes had to come out right in front of the rear tires. Who were we to argue?
Turbo System:
Comp C43 Series 72/75 .96AR Triplex Oil-less turbochargers
Tial Q blow off valves
Tial MV-R wastegates
Bell 30x10x4.5 front mount intercooler core
Vengeance Racing modified LS7 exhaust manifolds
3-inch oval charge piping and exhaust piping
DEI Titanium heat wrap
Complete turbo system fabrication by Vengeance Racing
With the turbochargers where the fuel tanks were, we obviously needed to build a new fuel system, which Jey did in house. A custom 18 gallon fuel cell was tucked nicely into the trunk, which utilizes an OEM fuel level sending unit for the street and track. Trust us, you don’t want to run out of E85 at the half! Twin Magnafuel pumps grab fuel from twin -12 lines, and send it down to the rails using a pair of -10 lines, which is enough volume to support big boost. There is also a Haltech flex fuel sensor inline, so that Mike can run any combination of E85 and still have the perfect tune up.
Fuel System:
Twin MagnaFuel 4303 Pro Tuner 750 pumps
Fore Innovations fuel pump controller
Haltech Flex-Fuel sensor for E85 conversion
-12 x2 feed lines to pumps
-10 x2 from pumps to rails/regulator
-8 return line
Magnafuel pre & post fuel filters
MagnaFuel 2000HP fuel pressure regulator
18 gallon custom fuel cell utilizing OEM GM fuel level sending unit
Speaking of the perfect tune up, SinisTTer relies on a Haltech Sport 2000 ECU for control, and with dual widebands, it’s easy for Mike to datalog runs and have the ECU correct for any potential issues. Inside, most of the C6 is still in tact – and all of the factory gauges work – although we did add a boost and fuel pressure gauge to keep Mike in the loop.
Engine Management:
ECU/Boost Control
Haltech Sport 2000
Dual Wideband upgrade
Haltech dual Wideband gauge
Autometer fuel pressure gauge
Autometer boost pressure gauge
The drivetrain is pretty typical of any high-quality Corvette that we build, with hard parts from RPM Transmissions, The Drive Shaft Shop, and RPS. A quad-disc clutch takes all of the abuse, tranfering power to the RPM Level VII TR6060 and the RPM Stage IV differential. A Quaife diff splits power to the Drive Shaft Shop axles, which turn (melt) a set of 18-inch Mickey Thompson drag radials.
Drivetrain:
RPS Quad Disc with RPS actuator
Tick adjustable master cylinder with long line/remote bleeder
MGW short throw with MGW ****
Driveshaft Shop carbon-fiber prop shaft
RPM Level VII TR6060 with MH3/ZR1 ratio
RPM Stage IV Differential with Quaife upgrade
Driveshaft Shop Axle/Hub Kit - 2000HP
Power… okay, we’ll just let the graphs speak for themselves.
7psi, 93-octane, M1 methanol: 942-rwhp…
12psi, 93-octane, M1 methanol: 1193-rwhp…
16psi, 93-octane, M1 methanol: 1327-rwhp…
20psi, VP C85, M1 methanol: 1492-rwhp…
23psi, VP C85, M1 methanol: 1586-rwhp!
“Through all this I knew I was getting a fast car, I was quick to realize after seeing their shop that I was going to get a high quality car. What I never expected was to make so many friends along the way to enjoy my hobby with. Ron has gone above and beyond what anyone would have done for me in terms of making myself and my family feel welcome. He treated us all with hospitality, enthusiasm and kindness. They're goal is to make everyone who comes through their door feel like family and they most certainly did that with me. It is not because of what we did either, Ron has treated everyone he encountered the same as if they were life long friends. This has been the greatest experience I have ever had with a purchase of any kind, best of all I get to re-enjoy it every time Ron texts me to see what’s up or when I start the monster up for a ride.”
Video:
TL;DR – 195mph in the half, 1586-rwhp, TT C6 for the STREET!
Last edited by David@Vengeance; 10-07-2013 at 05:00 PM. Reason: Double dipped on a dyno graph!
Old 10-07-2013, 03:08 PM
venom ws7's Avatar
An amazing epic build from the Vengeance Racing Crew great work
And Congrats Mike for the beast I'm loving the videos keep'em coming and be safe...
Old 10-07-2013, 03:11 PM
93civEJ1's Avatar
sick car
mrstepheneades's Avatar
On KILL for sure with this one.
Old 10-07-2013, 03:17 PM
T/A KID's Avatar
Wow thats sick
Old 10-07-2013, 08:20 PM
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
That car is the *****.
Sick build!!!!
Old 10-07-2013, 08:35 PM
willizm's Avatar
Fastest 2wd at the wannagofast street driven car? At the georgia event only or overall wannagofast?
Old 10-07-2013, 09:37 PM
95bowtie's Avatar
That thing is nasty, does it just have a roll bar?
I didn't see any roll cage bars by the dash or doors just in the back. You got some ***** to do 200mph with just a roll bar by your head....if that's the case haha
Old 10-07-2013, 10:48 PM
Just that weekend in Georgia. We'll be back for the OVERALL title
Old 10-07-2013, 11:00 PM
93camaro_zzz's Avatar
Did you seriously just make 942rwhp on 7 psi!!! Unbelievable!
Old 10-08-2013, 07:56 AM
Ryans99ls1's Avatar
Outstanding work!
Old 10-08-2013, 10:23 AM
V-seriesTech's Avatar
beastmode
Old 10-08-2013, 02:22 PM
gnx7's Avatar
That is a pretty incredible build. Nicely done Vengeance.
How much power was he running to do 195mph?
To show some of you guys how much aero comes into play at these 1/2 mile speeds....
My buddy went 193mph with about 900rwhp in a '93 RX-7 at the last 1/2 mile Shift Sector event. Runs a built LS9 with single GTS76 turbo and budget Stg 2 T56 rebuild with a McLeod RXT clutch. He was pedaling it in 2-4th gear due to lack of traction. Could finally put power down in 5th gear. Holley HP, self tuned, e85, no dyno time.
The frontal area of the car is probably 2/3 the size of a Vette.
Old 10-08-2013, 02:32 PM
ren987's Avatar
Great build Vengeance, and congrats Mike that thing turned out perfect!
I didn't know the fds were that much more aero dynamic, are supras about the same as an fd?
Old 10-08-2013, 06:38 PM
evillsx's Avatar
unbelievable car!! I think ron said 12??ish!
Old 10-08-2013, 08:33 PM
Nismo Kid's Avatar
Man thats a top notch build for sure No corners were cut. The fab looks amazing. But not to bring the tone down at all. Its probably the fastest 2wd at the Wanna GO FAST half-mile event/GA event. To be the fastest overall 1/2 mile car. Ive seen with my own eyes the Hennessey Ford GT do 220+, One of G-Force tube chassis cars do 210+ in the 1/2, The LMR/KP racing Camaro do 200+ in 1/2. There was also a few non shop cars that did 200+ in the 1/2. All at the Beeville TX Mile event. Your Car is Damn impressive 942@7psi holly cow man thats amazing.
Old 10-09-2013, 06:47 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Amazing setup.
Old 10-09-2013, 07:13 AM
TrentSS's Avatar
Truly amazing! Reading all this has made my start to this day a great one! More videos please
Old 10-09-2013, 09:38 AM
Sarg's Avatar
Wish they had beat that Gtr. That thing was fast though!
Old 10-09-2013, 04:56 PM
xfactor_pitbulls's Avatar
Fantastic build, and great write up. Nice to see a street car that isn't totally whored out putting down that kind of power and mph. Very clean work.
Quick Reply: VR SinisTTer - 195mph half, 1586-rwhp, Twin Turbo STREET C6!
