5.3 s10 time predictions and races
got my little truck running pretty good for a 5.3. first race is tomorrow night against a bbc nova. thinking he runs 7.80s in the 8th and then off to the track on the 19th to get some time slips.
videos will be taken
id like to get some educated guesses on what the ol truck will run compared to what others have run.
little info on truck
1991 single cab short wheel base
5.3 iron block
.20 over
mahle forged pistons
stock crank and rods with arp bolts
tsp v2 cam and supporting valve train
compression is 9.8 to 1 or so
heads are the step down from the 241s cant remember number
I had 2.02 1.60 valves installed milled .15
manley race flow valves intakes all back cut
heads are extensively ported both intake and exhaust
85mm intake ported with matching tb
1 3/4 maybe 7/8 cant remember brp long tubes with 3in exhaust to 2 40 series flows.
cold air
4500 stall th350 manual valve body
welded rear end caltracs trick flow cover
full interior
I have a guy out of Nashville tuning her.
wideband is still on the rich side at wot and rich taking off hope to have it lined out by the 19th.
whats she gonna run???? ill also be using atleast 150 shot on the 19th. I wont have it for the bbc hope I can still wax his *** for him
5.3 iron block
.20 over
cold air
full interior
iv heard bad things about flowmasters. ill look into getting some better mufflers. I was gonna make a pass with them at track and then take them off and get another pass. they say burn outs don't lie ill get a good video of a burn out and post it before I race the bbc nova tonight.
im the proud new owner of a broken nova u joint. bastard was gonna wax my ***. he sneaked in a stage of spray on me. went to do our burn outs and he scattered his u joint. but my truck stayed togeather I thought for sure I was gonna be the one broke. same guy is grudge racing our Malibu 1969 Camaro street car that use to be capable of high 5s
title says it all
i was the first vehicle on the track. started doing my burn out and snap!!!!! thought c clip at first up on getting her home found out axle was snapped in half so still no time.. got some 29x10.50 15s on the back it was gonna hook.
