93 ls1 RX7
93 ls1 RX7
Year: 1993
Make: Mazda
Model: RX-7
Price: $17000
Mileage: 64000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Gray
Transmission: Manual
Drivetrain: Rear Wheel Drive
1993 rx7 R1 $17,000 obo
Mitchell, IN 47446
98 ls1 t56 less 64k miles total rebuild according to Previous owner although I replaced every gasket but head gaskets 200+k on Chassis. I am un-sure of Actual mileage, but every nut and bolt on the car has been removed by me and I practically did a frame off restoration on the car if you can do that with a uni-body. I totally dismantled the entire car it has been a 3 year process so Don't let Mileage scare you everything on the car that is a wear item is Brand new. I have only put 2 tanks of Gas through it since I finished it and the first tank was pretty much used to bleed the cooling system which took forever.
Hinson Supercars sub frame
Brand new Spec Stage 3 clutch
Triax Shift Lever
Texas speed tr230-11 I believe it's the LS6 cam
Dual valve springs
Titanium Retainers
Chromolly Puch rods
New water pump
Home built Over the radiator intake using Modified Hinson Radiator set up
Braided clutch line and Remote bleeder mounted above Brake booster
Corvette fuel regulator/filter with all new fuel lines
Every hard brake line replaced new braided soft lines
New slotted rotors and Hawk Pads
New paint Dark Spiral Gray Metallic From a Chevy Silverado
New staggered 18x9 and 18x10 fr500 Black Chromate Wheels
235/40 and 265/35 Federal SS 595 tires
Re-wired whole car and moved fuse block behind driver's seat.
Brand new speed hut gauges
HID Headlights
Replaced all broken interior pieces
Removed all sound deading and replaced with dynomatt type material.
Suede headliner and A pillars
Super pro complete bushing kit
New pillow ball joints
Rebuilt ball joints, new Inner and outer tie rods
Samberg bump steer kit
Koni Shocks Ground control coilovers
New Sony Explode speakers.
Brand new Yellow top Optima
Tinted all exterior lights to match car
Freshly tinted windows 20% sides and 5% front and rear
Racing Beat 3" exhaust
Fresh Alingnment
No AC
ABS Delete
Only issue is the Drivers side Map pocket is missing.
NO TRADES.
Text or call 812-twosevenseven-67seven3
I have to sell it. I owe 4k on it becasue I had to borrow against it to replace the heat pump in my house or I would be up for possible trades. Any trade would need 4k Minimum on top of what ever they want to trade and have have a car worth at least 14k or so.
Come on buy it. I will work with you on the price some. I got an M3 sedan I want and have already test drove it. I Got the LSX swapped BMW on the brain and need to get my fix.
an 09 is similar but I can't afford to add money on top to get it. I think I may be picking up an M3 tomorrow so its gonna be a straight sale for sure probably. I got two guys who seem serious hopefully one of them is.
