Is this a no-no? turbo mount pics inside
Old 10-11-2013, 06:36 AM
baggins's Avatar
Default Is this a no-no? turbo mount pics inside
Was told by another member that using the compressor bolts for mounting isn't a good idea. Kinda makes since now that I think of it. Anyone have some input? Thanks
Old 10-11-2013, 07:13 AM
69-chvl's Avatar
Is the turbine housing mounted on the frame - hard to tell from the pics. I would think you would want a little give there even if the engine has solid mounts, all to allow for engine/chassis movement.
Old 10-11-2013, 07:48 AM
baggins's Avatar
The turbine housing is not. Just the 2 solid mounts on each turbo using the compressor housing bolts
Old 10-11-2013, 08:27 AM
Chevy406's Avatar
Visualize the headers growing from thermal expansion. Ask yourself what will be the path of least resistance to that growth?
In your case, since you have the compressor housing braced at the front and back you can be fairly certain there wont be any rotation or flexing in the compressor housing. There will be stress at the connection between the compressor housing and the center cartridge (i.e. compressor housing is fixed & header is pushing turbine housing forward). At the other end of the growth, there will be stress at the elbows coming out of the header flange and at the flange bolts. I personally thing that just a support underneath the turbo to support the weight, yet still allowing the turbo to move forward thermal expansion, will be a lot easier on the turbo and the headers.
Your installation looks top notch, and it's a shame to re-do the nice supports, but I do think you are putting things in a tight bind at operating temps.
Old 10-11-2013, 08:32 AM
baggins's Avatar
I'm thinking some bellows between the collector and flange might do the trick... Anyone agree
Old 10-11-2013, 08:39 AM
Chevy406's Avatar
Sure - if you can squeeze them in bellows will give the thermal expansion a nice easy place to do its thing.
Old 10-11-2013, 08:47 AM
baggins's Avatar
The bellows are 3" wide and luckily enough the collectors can still go back if need be because no primaries have been made.
Quick Reply: Is this a no-no? turbo mount pics inside
