should I do a ls6 stroker?
Thoughts on this? I will either do this with some higher compression pistons (12:1) with 91/93 or just swap pistons and rods and do a procharger big hp build. Personal thought, opinion, experience is what im looking for here. Looking to build a fun car on a budget that will be quick on the strip and circuit and occasionally drive to work.
I don't think high hp procharger build fits budget friendly. Lol.. I have been gathering parts just for the procharger build for the past few months. Not counting saving the funds to replace the rear end setup. $$$ A better question is how much do you want to spend. And where do you want the car to be in the next year or two.
stroker ? why?
http://forums.corvetteforum.com/c5-f...-347-d1sc.html
Be prepared for $$ for rear end, fueling, clutch, bushings, supporting items.
Fun car on a budget <>(!=) CTS-V Gen I, regardless which route you take.. it will at least be 'fun'.
Just do a supercharger... Rebuilding the LS6 seems to be more trouble than it's worth. I have been looking at just doing forged rods and pistons... Even then it's barely worth it.
stroker ? why?
anyway this guy has to be running forged internals at that power level. definitely something i would do though. I like that setup for sure. thanks for the link!
b) Be prepared to dump lots of fabbing, time and money to support FI.
What i will probably do is similar to what the guy on the vette forums did which pretty much was head cams exhaust and tune. I will probably buy the rear end right away for strength and gears. then enjoy that and go to a forged build with the same supercharger the vette forum guy did...
Building a stroker isn't a bad idea. Full rotating assy can be had for about 2 grand with everything you'll need. Biggest thing with strokers is getting a cam that will use those extra cubes. Strokers work great with FI as well but when you get up into big power you run the risk of piston rock/slap from the piston skirts being so short. Either way the V is always a fun car!
All I meant was budget does not equal modified cts-v Gen I. that was all. I guess the term 'budget' is relative.
Iron blocks are an option however stating considerably more power is incorrect.
This should be corrected to "more forgiving" for error with the Calibration. An LS Aluminum will hold 1000hp just as well as the iron cousin will - either no problem with the appropriate parts. However, if you like to calibrate where pre-det is abundant, when **** goes wrong, the Iron will take it, as well, if pistons let go, you probably have a block to re-run with vs cracking aluminum cylinders and that would be it. We can debate when going up into the 1500 range, however, I am sure that is irrelevant for this discussion.
I am a fan of sticking with the Aluminum unless one is aiming for a junk yard budget for pure power only.
I will echo what was in another post. With more HP you will find your weak links. Factor future breakage into your modding budget. Plus it gets more difficult to hook up so you end up running softer tires and having to change them more often.
scrapping the stroker idea and will go SC. A good set of forged pistons and rods will do and i will resleeve before I do a overbore since they dont cost too much money. should have a pretty beast setup from there.
