Stall
If you have the stall in hand , I say go for it. Your duration #s would help figure out whether the stall is close. With a 5.3, I think the stock torque peak is around 3800rpms , so even on a stock cam 5.3, that's not too much converter. The big thing about stall speed on a converteris , the stall speed is relative to the engine its tested with at the manufacturer and the engine the end user has. In a BBC ,that stall will be much looser than in your 5.3. The higher the torque, the higher the stall.
