LS3/L92 Victor jr throttle bracket????
Ok last thing i need is the throttle bracket..forgot about it...i still have the one that was used with the cathedral dual plane but it won't fit the ls3 vic jr...what is everyone using for a throttle bracket with the ls3/l92 victor jr intake??? Have a 700r4 Trans also....need to order today
Mine bolted to the left rear carb bolt and one of the intake bolts when I had the Vic Jr on mine. For the life of me, a cant remember who makes the bracket ?! If it comes to me I will let you know. I would send you mine , but I modified it to work on my GMPP dual plane. Have you looked on Edelbrocks website for a recommendation? They should know what it takes.
Thanks, I've been looking everywhere for one...didn't see anything over at Edelbrock, just the one i already have..tried using google but that isn't helping much..guess i could try giving Edelbrock a call and see..thanks alot, thought maybe i can get a party number from you guys..
Man, I feel for ya. Im pretty fair at fabricating stuff out of parts I have laying around. I just don't have any idea what you are dealing with because I have never looked at the cathedral head bracket. All Ive ever had was LS3 carb intakes to deal with. All the cat head stuff Ive worked with had a plastic intake . No way you can grind the wrap around bracket to fit the bigger intake?
Hey I'm pretty good at fabbin up parts also, the eddy bracket now i had to fab a little bit to work right...the mounting on the ls3 vic jr, one bolt (back intake bolt) is sitting right on head...the bolt before that one is about 3" up the runner..so there is 4" bolt and a 2" bolt that's holding the rear of intake down if you all can picture that...i asked 3pedals already and he said he's using a mechanical linkage..
I made mine out of a 3/16" sheet of aluminum. Use a carb base gasket as a template and leave some material on the throttle cable side to bolt your throttle and trans cable to. You can pick up one of the cheap mr. Gasket type brackets and just use the L shaped brackets and bolt them through the fabricated piece. Works great and is cheap to build. You can polish it up and looks good.
That's what makes building a car so fun to me. Beat, bang, cut, tweak, shim, recycle, file, drill, and paint to match ! One of a kind, built with your own twist on what it should look like . Pride in production ! For me , there is nothing like knowing how tight every bolt on the car is, because I tightened it ! Hot Rod ingenuity !
