8.8 Id
Old 10-22-2013, 06:04 PM
notinuse's Avatar
Default 8.8 Id
Is that a friction disc behind that spider gear? I'm trying to get a better pic from its owner before I pick it up.
Old 10-22-2013, 06:25 PM
notinuse's Avatar
Is this a posi or open carrier?
Old 10-22-2013, 07:43 PM
luch90's Avatar
that is a friction disc behind the spider gear. its a ford trac loc differential/posi
Old 10-22-2013, 07:46 PM
andrewss's Avatar
That is a posi, you can see the tap for the clutch plates. What is your plan with the 8.8?
Old 10-22-2013, 07:52 PM
S10xGN's Avatar
The "S" spring gives it away, definitely not open.
Quite a few of them behind the spiders...
Old 10-22-2013, 08:12 PM
notinuse's Avatar
Thank you. It's going in my car. 8.8 I believe is my cheapest option for a 450 rwhp m6 car with sticky tires.
Old 10-22-2013, 09:29 PM
ls6jay's Avatar
Love mine. Install ford racing clutches. 100.00 or so.
Old 10-23-2013, 07:32 PM
S10xGN's Avatar
The truck "S" spring is supposedly the heaviest too. Got that spring and the above clutches in my S-truck, it'll chirp around corners if the pavement is hot enough...
Quick Reply: 8.8 Id
