88mm,High ram, all black turbo build.
Old 10-22-2013, 07:51 PM
Ka-Kevin's Avatar
Default 88mm,High ram, all black turbo build.
This is my 99 Z28 moser FAB-9 TH400 stock bottom end small cam. Enjoy
Attached Thumbnails 88mm,High ram, all black turbo build.-image-4007829403.jpg   88mm,High ram, all black turbo build.-image-3210151894.jpg   88mm,High ram, all black turbo build.-image-3535883372.jpg   88mm,High ram, all black turbo build.-image-3558650248.jpg   88mm,High ram, all black turbo build.-image-3832309316.jpg
88mm,High ram, all black turbo build.-image-1613777662.jpg   88mm,High ram, all black turbo build.-image-4116251851.jpg   88mm,High ram, all black turbo build.-image-592315444.jpg   88mm,High ram, all black turbo build.-image-1610542605.jpg   88mm,High ram, all black turbo build.-image-3096654162.jpg
88mm,High ram, all black turbo build.-image-1749551632.jpg   88mm,High ram, all black turbo build.-image-2154077699.jpg   88mm,High ram, all black turbo build.-image-1163479070.jpg   88mm,High ram, all black turbo build.-image-3068899840.jpg   88mm,High ram, all black turbo build.-image-2832447278.jpg
88mm,High ram, all black turbo build.-image-3133637280.jpg   88mm,High ram, all black turbo build.-image-3720437979.jpg   88mm,High ram, all black turbo build.-image-3044979152.jpg   88mm,High ram, all black turbo build.-image-17993799.jpg   88mm,High ram, all black turbo build.-image-3591664264.jpg
88mm,High ram, all black turbo build.-image-2223276899.jpg   88mm,High ram, all black turbo build.-image-3476752224.jpg   88mm,High ram, all black turbo build.-image-727429236.jpg   88mm,High ram, all black turbo build.-image-3695535062.jpg   88mm,High ram, all black turbo build.-image-1473534421.jpg
88mm,High ram, all black turbo build.-image-1765102633.jpg   88mm,High ram, all black turbo build.-image-2955515520.jpg   88mm,High ram, all black turbo build.-image-2906754562.jpg   88mm,High ram, all black turbo build.-image-1626149373.jpg   88mm,High ram, all black turbo build.-image-2314985918.jpg
88mm,High ram, all black turbo build.-image-135026688.jpg   88mm,High ram, all black turbo build.-image-2294313729.jpg   88mm,High ram, all black turbo build.-image-676906685.jpg   88mm,High ram, all black turbo build.-image-2911775581.jpg   88mm,High ram, all black turbo build.-image-1706017436.jpg
88mm,High ram, all black turbo build.-image-411954105.jpg   88mm,High ram, all black turbo build.-image-647938905.jpg   88mm,High ram, all black turbo build.-image-2533167604.jpg   88mm,High ram, all black turbo build.-image-3299186007.jpg   88mm,High ram, all black turbo build.-image-609048435.jpg
88mm,High ram, all black turbo build.-image-320728857.jpg   88mm,High ram, all black turbo build.-image-1299087569.jpg   88mm,High ram, all black turbo build.-image-2214288452.jpg   88mm,High ram, all black turbo build.-image-193634846.jpg   88mm,High ram, all black turbo build.-image-490286155.jpg
88mm,High ram, all black turbo build.-image-2132598150.jpg   88mm,High ram, all black turbo build.-image-677716765.jpg   88mm,High ram, all black turbo build.-image-3527894602.jpg   88mm,High ram, all black turbo build.-image-3297194127.jpg   88mm,High ram, all black turbo build.-image-2716899742.jpg
88mm,High ram, all black turbo build.-image-2841585134.jpg   88mm,High ram, all black turbo build.-image-3197324522.jpg   88mm,High ram, all black turbo build.-image-1816771294.jpg   88mm,High ram, all black turbo build.-image-3486042429.jpg   88mm,High ram, all black turbo build.-image-740512079.jpg
88mm,High ram, all black turbo build.-image-2064754962.jpg   88mm,High ram, all black turbo build.-image-655048258.jpg   88mm,High ram, all black turbo build.-image-636429096.jpg   88mm,High ram, all black turbo build.-image-615065535.jpg   88mm,High ram, all black turbo build.-image-3085977241.jpg
Old 10-22-2013, 08:20 PM
GLS
GLS's Avatar
Looks great, any numbers on this build? What turbo?
Old 10-22-2013, 09:04 PM
T76s10's Avatar
I vote gt-5533 88. Looks like a large frame unit
Old 10-22-2013, 09:36 PM
Pete91's Avatar
Holy pics batman!!!
Old 10-22-2013, 10:25 PM
Ka-Kevin's Avatar
It's a 47-88 all work done by Fast Track Performance I'm sure most of you have herd of it awesome work and a great guy. Looking for 600 RWHP keeping it mild for now building a 370 looking for around 1200 on it.
Old 10-23-2013, 02:15 AM
a98ws6's Avatar
Did you have to space the k-member to fit the Hi Ram?
Old 10-23-2013, 01:19 PM
Ka-Kevin's Avatar
No i did not but there is only about an 1/8" from the windshield so i did go with solid motor mounts
Old 10-23-2013, 02:21 PM
BMF_Racing's Avatar
Love the black. 600whp, lol. Must be planning really low boost.
Old 10-23-2013, 03:24 PM
a98ws6's Avatar
What model are you using? For ls cathedral heads?
Old 10-23-2013, 08:19 PM
Ka-Kevin's Avatar
Yes it is the cathedral with a 102mm TB and a race parts quick disconnect looks much nicer than a Vband.
Old 10-23-2013, 08:28 PM
Ka-Kevin's Avatar
There was a lot of time put in this build to make it as clean as possible and look great I'm glad Anthony took the time he did and put up with all the changes I came up with and also ading his advice (much needed). There is only one rubber line on the car and it is on the bottom of the wast gate. All the rest of the lines on the car are braded stainless with black fittings even the -20 radiator hoses ����. The car is on E85 with one in tank pump that feeds three thirsty pumps in the surge tank going to 127lb injectors. It will be on low bost for now but built to take what I can throw at it.
Old 10-29-2013, 09:04 AM
Ka-Kevin's Avatar
Got her on the rollers made 597 at 14lbs and then we turned it up just a bit 762 at 18lbs
Attached Thumbnails 88mm,High ram, all black turbo build.-image-1649512671.jpg
Old 10-29-2013, 09:47 AM
a98ws6's Avatar
Looks really nice. Id like to see some pics of the outside of the car.
Old 10-29-2013, 12:48 PM
Rise of the Phoenix's Avatar
How much more is left in that turbo?
Old 10-29-2013, 01:31 PM
Ka-Kevin's Avatar
waiting to get the new hood fitted and painted. Here is one from right before it got torn apart.
Attached Thumbnails 88mm,High ram, all black turbo build.-image-4061616090.jpg
Old 10-29-2013, 01:37 PM
Ka-Kevin's Avatar
. That is the same thing I'm wondering lol. It should have no problem making 900whp on this size motor (stock LS1) but could prolly support almost 1200 on a 5.3 the exhaust housing has a lot to do with making power on a V8 if I do got with a 370ci motor in the end I will upgrade to a 100+mm turbo to support my goal of 1200whp.
Old 10-29-2013, 09:12 PM
HolyShiznit's Avatar
I know block/internals/heads are stock but what oil pump, timing chain, valvesprings, etc did you go with. Your car is almost an exact visual clone of mine and I am about to put on my turbo kit.
Old 10-31-2013, 05:50 AM
1bad03snake's Avatar
What radiator and fan are you using?
Old 11-01-2013, 02:14 PM
Ka-Kevin's Avatar
Stock oil pump/chain and all 279 comp cam with there lifters and springs. The radiator is custom order I can't remember the measurement on it the fans are flexalite
Old 11-01-2013, 02:16 PM
Ka-Kevin's Avatar
Summit racing has the radiator and just about any other size you need I want to say mine is a 27x17x2.5
Quick Reply: 88mm,High ram, all black turbo build.
