Need input on gears for a 9" turbo car with auto
Old 10-23-2013, 08:58 PM
jrpimp00's Avatar
Default Need input on gears for a 9" turbo car with auto
Got no help in the Gear & Axles forum.
Getting ready to order a moser 9" but cant decide on gears. Specs are below but haven't decided on a tire size yet. Any help would be appreciated. Car will be a weekend driver that will see the 1/4 mile 1 or 2 days month.
2004 LQ4
224r Cam 114 LSA
Built 4l60e (will be upgrading to built 4l80e next year)
7875 turbo 1.15 ar
Full weight car with a fatboy in the seat
Made just shy of 680 on 12psi
Graph is with 10 bolt and 3.73 gears
Looking for a good starting point, consensus seems to be 3.25 or 3.50. Not looking for a specific trap speed just a good gear to get down the track and drive around town
Old 10-23-2013, 09:51 PM
Photochop's Avatar
Either would work. Keep in mind max rpm and tire diameter if you're considering the 3.50s
Old 10-23-2013, 10:13 PM
CameronVic's Avatar
If you put tire height, I missed it. If 26s, do the 3.25, if 28s, do the 3.50. Just an opinion.
Old 10-23-2013, 10:27 PM
SPRAYED 01's Avatar
I run that trans with 325s and a 28inch tire, 3600 stall. I love the setup. Can't go wrong with what i have. If you don't plan on going over the 6xxwhp then a 350 would work just fine.
Old 10-24-2013, 04:48 AM
samdogmx's Avatar
28s & 3.50 here
Old 10-24-2013, 05:14 AM
Camaro9969's Avatar
All depends on tire size. 28 3.50s would be great with that transmission. Even 3.25s you would love that for highway cruising
Old 10-24-2013, 07:15 AM
jrpimp00's Avatar
Thanks for the replies
Old 10-24-2013, 07:33 AM
RedRocketZ28's Avatar
With a 28" tall tire and 3.25's, I trapped 140+ with a similar setup on 14-15 lbs. That was going through the traps around 6k if I recall. My fuel cutoff is 6,350 and it hits that at 146 or so in 3rd gear. My converter is a little loose but works well. I don't plan on spinning my engine any higher than that so I am going to 3.00 gear in mine, but also going with a bigger turbo.
So...depending on what you want out of the car, tire size, and how high you plan on spinning the engine, I think a 3.25 would work well. I drove around for a few months on 2.73's and honestly, I didn't hate them. Pulled hard on the highway but with my looser converter it was a little bit of an annoyance driving around town.
Old 10-24-2013, 07:40 AM
BMF_Racing's Avatar
Thumbs up
I agree with everyone that says 3.25's. I have 28x10.5" and 3.25 gears in mine and they worked perfect with the stock LQ4 at 6000rpm redline (140ish mph) and also great for the new engine (7000rpm) and tight converter 160+ mph should not be an issue.
Also 3.25's will be nicer on the highway if that matters ... good luck.
Old 10-24-2013, 07:49 AM
Moderator
denmah's Avatar
we have 28s and a 3.70 gear ford 9 inch in a 2002 fbody
traps 137 best so far still rpm to go
Quick Reply: Need input on gears for a 9" turbo car with auto
