50 Chevy LQ4 4L80E swap.
Newbie here guy's thanks for all the great info here. My current project is a 1950 chevy I been working on it for a while. I have done tons of metal work I am pretty much up to the firewall so I been lookin for a motor and just picked up a LQ4 4L80E and here I am. Just went though harness I have to make up fuse and relay panel still. Set it in last night to see where I am at with fitment.
been making a little progress got motor set in. finished up fabing up front end, shock mounts, upper control arm/air bag mounts. Made new firewall and installed it. new K member trans cross member
31, The metal work is awesome. I’m currently doing the interior sheet metal on mine and it doesn’t look nearly as nice as this. I will be doing something similar to what you did in the trunk with a removable section giving access to the fuel tank and battery. Looks good. Post more pics right side up.
Thanks DEEDDUDE I am getting close to having all the metal work done. been working on door, trunk gaps hope to get it media blasted and in some primer soon.
Looks really good. I have a 50 business coupe that I'm looking to do the same thing. I just blew my motor fund on a 2 post lift but I will be mocking a 5.3/4l60e as soon as I get my lift installed.i don't know if I will z my frame or not. I am going to get that bulky k member out of the way and see how she sits. Looking forward to more build pics.
Welcome to the 49-54 Chevy LS Swap Club! Great looking build so far. I noticed you notched the frame to run the steering shaft... Do you have any more pics of how you did it? I am currently trying to get my steering sorted out and I think I am going to have to do that with mine.
Keep up the good work!
Ok. That's what I was thinking of doing, just wasn't sure if that was the "right" way to do it... Does notching the frame like that hurt the strength of the frame at all? That is my biggest concern.
