swap into silverado straightforward?
So you already have an LS motor in your truck you just want a bigger engine I'm guessing. A 6.2L should be pretty straightforward. You could buy a long block from GM and just swap all of your accessories over. You want to stick with a GEN IV engine. LS1 and LS2 are GEN III. Honestly for what you will have in purchasing another long block and labor to put it in, you could just do a twin turbo setup on your stock engine. The 4.8L engines love boost. Hot Rod magazine made 1200hp on race gas and never blew up the stock bottom end.
true, but i dont really want to mess with fueling, plumbing for two turbo's or even one, and tuning with sd, finding a new tranny and rear end, ect...what i do want to do if find a vehicle with a gen four motor that is an lsx of some sort and swap the two so I can boost the hell out of it in a base vehicle that will allow me to go faster. That will probably be a g8 gt with the ls2. So you guys kinda get what my plan is, what i am trying to figure out if i just swap the two motors and ecu's and im good to go? Or is there a little more involvement?
Still not clear on what swap you are trying to do . Hope this helps you decide.
If you want to put a 6.0 in your truck. Look for the following L-76 truck version not car, LY6 OR L-96. If you want to delete the VVT , you probably can use your harness and ecm also. The L-76 is VVT and AFM and are not cheap so your best bet is LY6 or L96. Or step up to a 6.2 L92
ok, say i get a G8. I already have the 2010 silverado with the 4.8. I want to swap the two between each other. Do you get what im saying now omc8? so my questions once again is: is this going to be easy to do and what specifically, if anything, needs to be done? Like you already said, both are fourth gen so that alone should make it easier. right?
Pretty much. The G8 came with three engine options. L76 3.6 v6, LY6 6.0 v8, or the LS3 6.2 v8. You'll need the LY6 6.0 truck intake since it's a retangular port. Using the truck intake and rails will keep from having to resorting to modifying the fuel lines to fit the car intake rails. Just make sure to get it tuned for the new motor. A simple mail-order tune should do.
Good luck on the swap.
the thing is i dont want to introduce a third engine into the mix. I want to know if it is possible to swap these two between each other and if it is, what does it entail? if not then im not going to do anything but upgrade and boost both...
11 year old thread? You expect OP to respond? He might.....
