New plan, 8.50 or bust!
The car ran very well with the SBE 6.0 and spray but it's was basically a 1/8th mile only car so since the motor is hurt its time to go a new direction. Then plan is to build a 370 with my prc stage 3 243s around. 10-10.5 to 1 compression, custom grind cam, pro systems carb and a forced inductions s480 et-r billet wheel turbo with a air to water setup. Plan is to drive to to the track run 8s and drive it home. Should weight 3000-3100 race weight when finished. You guys think 8.50s is out of it is too much to ask?
My sbe 6.0/S480 has gone 9.57 @ 147 so far in my 3500lb Camaro, with a crapy 60ft. There is lots left in it. My goal is 8's as well, and I am confident the combo can ultimately go close to 8.50. I trailer to the track. You never know what will break with a stick shift!, but this is still a street car.
