Wow I'm an idiot
Wow I'm an idiot
I was looking at a pic of my garage and I saw my leftover fluid bottle still sitting on the shelf from when I changed the rear diff fluid. It was Pennzoil Syncromesh. I must have grabbed the wrong bottles at the store and not paid attention afterwards. Can't even remember at this point what I was thinking.
The really sad thing is this was a year and 10,000 miles ago. Funny thing is there's no symptoms or noise from diff and it has 103k miles on it. In fact I remember it got a little quieter when I changed it. Anyways, gonna change it ASAP back to a 75/90.
I would actually expect it to run quieter, but break down really, really, fast. It won't hurt the bearings as there is not much difference from transmission bearings to diff bearings other than size. Just heat and pressure is why gear oil is used. The diff (between gears) causes so much heat and pressure that gear oil is designed to hold up, where as other oils are not meant to with stand these two parameters. Thus why gear oil is like syrup.
Anyway, your problem would be how long it was ran. I would expect that synchromesh to break down in the conditions of the diff in a few thousand miles to where it starts loosing its lubricity, and may start causing damage to the bearings. Either way, at least it wasn't a 9" or 8.8!! Good luck!
blah, just switch it out, i doubt you did any harm.....hell in a pinch up here, we run automatic transmission fluid in the chain drive gear cases of our snowmobiles, some people run exclusively ATF, i know its different conditions, the sled is probably more severe IMO. your probably just fine.
Swapped it out tonight. You can see below the old stuff looked pretty beat and destroyed. I want to make sure the LSD works fine still but otherwise the diff has no noise and no metal to speak of came out with the old fluid.
Here's a sample of the new Redline I put in (in a dirty cup). 75W90. Has friction modifier built in so does not need anything else according to redline for the LSD.
Here's the Synchromesh I took out. It was still oily but.... just needs some creamer and you've got a latte.
Old Pennzoil synchromesh - YouTube
This was how my Transmission Fluid came out lol
Got a gallon jug full of the crap now!
Brake pedal to the floor. Anything rubber that the PS fluid touched was ruined. Luckily, no accidents were caused. Those two bottles should never be placed next to each other on a shelf.
http://www.agcoauto.com/content/news/p2_articleid/251
Last edited by BudRacing; 11-19-2013 at 06:37 PM. Reason: added link for reference
