modest LQ4 into a 1968...journey of a 1,000 miles starts with the first step
So it starts. I picked up my LQ4 and now I'm starting the process of assembling all the parts for the swap into my 1968 Camaro RS.
My goals:
400+ rwhp & torque with a broad torque and horsepower curve.
2,000 - 6,800 RPM range
How I Plan on Getting there:
Stock LQ4 intake
799 Heads with dual valve springs
Howard's Cams LS1 LS2 LS6 CHEVY 224/230 .609/.604 112° camshaft
Stock rotating assembly
Hedman Husler mid-length headers 1 3/4 primaries 3 inch collector
Performance tune
What I have already purchased:
The LQ4 from a 2000 GMC Sierra - 120,000 miles
Used stock pistons and rods from an LS2
Melling Hi-Flow oil pump
Soon to happen purchases:
Stock crankshaft from an LS1/LS2, cleaned and machined (evidently my crankshaft won't work with the T-56)
Rebuild kit with rings and bearings
LS2 timing chain kit
Mast swap oil pan OR Moroso swap oil pan?? Haven't decided yet
Machine Work Planned
LQ4 Block hot tanked and magnafluxed possibly blueprinted
Crankshaft, rods and pistons rotated and balanced
Garage Work Planned
Harness
I will remove, catalog, clean, and modify the harness and sensors. I plan on modifying the harness myself. I know its tedious but I don't have a ton of money to spend on a swap harness and I don't mind putting in the hours.
Long Block
Disassemble the long block. All parts will be cleaned and cataloged.
My goals:
Stock LQ4 intake
Performance tune
Garage Work Planned
Harness
Long Block
Harness removal
Harness has been removed and all connectors cataloged. I've never modified a harness before but I'm willing to give it a shot.
I took a picture of each connector and tagged it so I can reference what the connector was attached to later while I'm modifying the harness.
A lot of connectors going to smog related stuff I could already tell were going to get eliminated. Some connectors are going to sensors/equipment I have no clue about.
Soon I will be disassembling the engine and cataloging those parts as well.
Then the machine shop!
Yep, me and Nate .... well mostly Nate, I just wrote it down
Absolutely! When I read the article , picture #5 mentioned something about a wiring diagram included in the article but I couldn't find it. I went to the GM High-Tech website and couldn't find it it there either.
Do you have a link or a file you could send me?
For some reason, I can't post photos, only the LS2 Pistons and Rods went up
BUT...
I now currently have an LS2 Rotating assembly and a Melling Performance Oil Pump [the 10296] and I have a lead on some good used 799 heads.
Planned for this week, disassembly of the LQ4 down to the bare block. This week is short because of Thanksgiving so the block will be off to the machine shop in a week for hot tank, magnaflux.
The crankshaft will be sent to Ed's Crankshafts in Hayward for machining.
Once everything is together, assembly of the short block and purchase of the oil pan and camshaft
Thinking about getting the 799's milled for more compression...
Hopefully, I can figure out why I can't post more than one photo.
BUT...
I'll see if I can send you one.
If you can hold out a little longer I have a book coming out with everything you'll need to know about doing the swap including all the wiring diagrams.
Swap LS Engines into Camaros & Firebirds: 1967-1981 (SA Design): Eric Mcclellan: 9781613250310: Amazon.com: Books
when will the book be released?
