Ok I'm changing my exhaust one last time.... Suggestions
My current set up is true duals under axle to flow master 1 chambers before tips. It's flanged at the axle, so I'm gunna pull the tailpipes off, and build another set. Probably just different mufflers dumped. The flow masters don't sound great ever since I ran them out to the back. Raspy and a lot of drone. So what mufflers should I run? It's also way too loud. Magnaflows? Borla? Spiral flows?
Here's the set up. You can see where it's flanged.
I've been looking to do something similar with mine. The 408 is too much exhaust for the 3" i pipe. I was looking at running Magnaflow bullets where normal dumps would be for tone with cutouts then run under the axle to some XL3 mufflers. All in 3" stainless.
Probably do it after Thanksgiving.
