Will this racetronix dual pump set fit in the plastic bucket?
Old 11-25-2013, 10:06 PM
703 CAMAROSS's Avatar
Default Will this racetronix dual pump set fit in the plastic bucket?
I was looking at getting a dual pump set up soon and I really like the looks of this and how the pumps come together. I think it looks really clean? Any opinions? http://www.racetronix.biz/itemdesc.asp?ic=DPA%2D680&eq=&Tp=
Old 11-25-2013, 10:30 PM
NOS LS1's Avatar
Im pretty sure the Plastic Bucket will have to be modified to fit Dual Fuel pumps.
Contact Lonnie here on LS1 Tech. He is a sponser on this site.
Lonnie can modify your fuel pump bucket for dual fuel pumps or i think he has an exchange program.
Heres the link...
http://www.lonniesperformance.com/doublepumpers.htm
Old 11-26-2013, 07:37 AM
rorric's Avatar
That set up from racetronix look really nice and you don't have to worry about spilting line at the y.. anybody use this in a f-body set up yet?
Old 11-26-2013, 06:11 PM
I know the bucket needs to be modified but will the bracket and all fit after being modified? Looks like a great set up. I may just order it and try and if not il take the bracket off. It's only 40 bucks more then ordering the pumps separate.
Old 11-26-2013, 06:14 PM
It looks to be the same width as just having double pumps. The pumps look wider then the bracket it's self. I bet it will fit.
Old 11-26-2013, 06:20 PM
I'm sure lonnies set up is really nice no doubt and I was going to buy it but I can piece it together for 2 or 300 dollars cheaper building my own harness and putting the pumps in my self and all.
Old 11-26-2013, 11:23 PM
NOS LS1's Avatar
Default Lonnies Dual pump set up
Lonnie is a specialist in F Body Fuel systems.
He has spent alot of time designing, building & testing these systems.
The Dual pump system allows you to run on 1 fuel pump in normal driving.
When you activate a nitrous system or build boost, it turns on the second pump.
Secondary pump only runs on demand when xtra fuel is needed.
This creates less heat in the fuel system.
Old 11-26-2013, 11:33 PM
I get this and you can build the same harness for around 300 bucks if you know how to solder.
Old 11-26-2013, 11:48 PM
I just added it all up and the harness is going to cost me 164.54 to make. That is just the harness that dosent include the fuel pumps and fuel hose. You can buy everything you need from racetronix
Old 11-27-2013, 08:16 AM
rorric's Avatar
Can these pump handle e85?
Old 11-27-2013, 10:37 AM
It says e85 will shorten the life of them but I'm not sure what that means exactly. I either need those or the Aeromotive stealth 340lph pumps. I'm going to try them with e85.
Old 11-27-2013, 10:56 AM
Somebody09's Avatar
as long as lonnie continues to sell hacked-up OEM buckets, he's not providing anything that a DIYer can't do on his own. if it were something special, he'd proudly show the details of his work (like other double-pumper companies of other platforms do), not those ambiguous thumbnails found on his website
Old 11-27-2013, 01:55 PM
LS1TECH Sponsor
Racetronix's Avatar
Do you / have you owned a DP system from Lonnie's Performance?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Quick Reply: Will this racetronix dual pump set fit in the plastic bucket?
